Old 08-21-2010, 06:31 PM   #1
1972 25' Tradewind
San Diego , California
'72 AS hot water heater function question
Forgive me if this has been asked a hundred times. I looked but did not see the info I needed.
All of my gas appliance work well and there's propane in the tanks. However, don't seem to be able to get the hot water heater to light. Based on the instructions, I expect that if I hold the read "clear" knob down long enough (with the control know set to pilot and the temp on low) I ought to smell gas and I don't. I do have a shut off valve under the trailer that feeds the furnace and it is on and seems to be in working order.
So... is that magic box something that may be not functioning correctly?
Thanks guys, never been "lucky" enough to have a trailer with a hot water tank so its new to me!
James
icebox500 is offline   Reply With Quote
Old 08-21-2010, 08:45 PM   #2
stephenh2's Avatar
Tyler , Texas
I had a shutoff valve inside in an awkward location. I looked several times and didn't recognize what it was. You might have one there as well.
Stephen
Home again in Tyler, Texas
Please visit any time!
stephenh2 is offline   Reply With Quote
Old 08-21-2010, 09:52 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Very little gas comes out the pilot tube, but you should have some.
My 75 TW has a shutoff valve directly under the water heater running along the belly pan.
If that is good, you might have a blockage in the pilot tube caused by incests. You could disconnect the tube and try blowing it out.
Richard
Old 08-22-2010, 11:18 AM   #4
1972 25' Tradewind
Thanks folks, that was the encouragement I needed. Once I verified that there was only one shut off valve inline I took apart the pilot and burner and cleaned up the gunk, rust, and spiders. Ta-Da - it works!
I didn't dig into the incest though... ;-)
Old 08-22-2010, 11:35 AM   #5
x
XXXX , XXXX
Incests that was a typo. I think he meant insexts LOL
wasagachris is offline   Reply With Quote
Old 08-22-2010, 12:56 PM   #6
James
James.
I cannot imaging what appliance you had trouble with?????
Airstream has never used a "hot water heater".
But................they have used "cold water heaters" for many years.
Bottom line is more important, that you got the "thingy" working ok.
Old 08-23-2010, 05:26 PM   #7
1972 25' Tradewind
I thought maybe there was an inappropriate relationship between the heater and the fridge... I guess that would explain the cold water heater!
Old 08-23-2010, 05:30 PM   #8
Airstream also uses "cold air" heaters.
Old 08-23-2010, 05:39 PM   #9
2002 25' Safari
Dewey , Arizona
Images: 62
"Hot air" coolers are a popular option as well.
Richard
Old 08-23-2010, 06:18 PM   #10
x
XXXX , XXXX
Andy on a similar note I once had a rental customer ask where he fills up the electricity. I wasn`t sure what he meant and asked him to clarify his request. He then asked for the location of the tank for the electricity so he could fill it to use the microwave and air conditioning while on the road in the rental motorhome. You just never know what to say in response to that question.
Old 08-23-2010, 06:58 PM   #11
Splitrock's Avatar
Sioux Falls , South Dakota
I asked the flight ticket agent for a round trip ticket and he asked, "Where to?". I said, "Round trip . . . right here".
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 03:35 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 01:24 AM
Hot Water Heater ?????? davidh Water Heaters, Filters & Pumps 7 02-28-2006 08:25 AM
Nobody needs a hot water heater!!! Rick Alston Off Topic Forum 109 02-13-2004 10:52 PM
hot water heater 53flyingcloud Water Heaters, Filters & Pumps 4 07-08-2002 11:18 AM
