Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 08-03-2006, 02:15 PM   #1
Gen Disarray
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
68 water pump-should the pump cycle?
My water pump kicks on for a few seconds every 15-20 minutes. Is this normal? I don't see any leaks. Is there a one way valve down stream of the pump that might be leaking? If it isn't normal I need to do a better leak search.
Rodney
On a magic carpet ride
Visit my photography page at:http://www.pbase.com/professor_chaos
Gen Disarray is offline   Reply With Quote
Old 08-03-2006, 02:42 PM   #2
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
yeah, its loosing pressure, somewhere...very slowly. check the city hookup. does it drip.....drip.....drip....? there's a check valve in there somewhere that keeps the pump from just sending the contents of your fresh water tank right out the back. could also be internal to the pump.
mine cycles alot more often than that. (because my check valve is shot). Even when I have the plug in the city hookup. unless you teflon-tape the threads and knuckle it down, it isn't really sealed up perfectly, so there's always a little leakage. earlier this season, I found that my fairly new plug had a pin hole in it. guess how? the stream was so thin, it was only detectable when I was standing in it. I thought some ill-mannered canine was marking his territory, for a split second.
I'd like to replace the check valve...even bought a replacement...but its unreachable. the bathroom will need to be removed in order to get at the damn thing.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-03-2006, 02:44 PM   #3
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Check for leaks - as in right now. Could be that something is dripping in a hidden place, promoting wood rot.
Could also be the toilet flush valve, or a one-way valve in the pump itself going out. One way valves keep the pressure in the system from releasing back into the tank. The one you're looking for is most likely integral to the water pump.
Uwe
Old 08-03-2006, 04:03 PM   #4
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
It is not normal. After I purge the air out of my lines, the pump never comes on unless I open a valve.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 08-03-2006, 07:55 PM   #5
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
It is most likely the check valve but could be a leak somewhere else too. Grit and/or calcium deposits can prevent it from closing or the seal could be shot. Mine has two and when the pump started cycling last year, I replaced them. One had a bad seal and one just needed cleaned out. Happened again this year so I unscrewed it, cleaned it and no more cycling. This is also the first year I didn't run a filter so its my own fault but fortunately I have easy access to both of them. I would look there first Gen.
In edit, the Airstream I was referring to is not my 68 Overlander but they all have check valves. You might not have two.
Old 08-03-2006, 10:26 PM   #6
Janet
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
Rodney, What you are describing is how we've found every leak, loose connection ind pinhole we ever had.....sorry.
77 Argosy Minuet, 6 metre
77 Argosy 24, Rear door
AIR 3181, WBCCI/VAC # 5575
Wally for President
Janet is offline   Reply With Quote
Old 08-04-2006, 10:40 AM   #7
Gen Disarray
Lawton , Oklahoma
I was afraid it might be a leak, cant find it yet if it is though. In the mean time I am turning off the pump when I am not using water.
Rodney
Old 08-04-2006, 02:07 PM   #8
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
That's what we do. The waterpump going off by itself sets me on edge because I know there's a leak somewhere. This last trip it went off once in the middle of the night, and I jumped up and started checking the usual places for leaks. Mostly we leave it off when we're not using it (and i never use the city water hookup).
Good luck hunting it down!
Stephanie
Our family photo blog
Old 08-06-2006, 11:11 AM   #9
Chuck
Sad Moderator
Chuck's Avatar
Images: 99
update: fixed mine! check my latest in this thread: http://www.airforums.com/forum...ues-24978.html
Air:291
Wbcci: 3752
'73 Safari 23'
Water Pump cycles often Guitars Water Heaters, Filters & Pumps 3 11-19-2002 08:04 PM
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 07:31 AM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 10:13 PM
Water pump has quit roessler Water Heaters, Filters & Pumps 8 08-14-2002 04:02 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 11:35 AM
