Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 10-07-2007, 11:51 PM   #1
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
Airstream Registry
'66 TW. Bowen OUT, Atwood IN.
Spring of '07 I replaced our old Bowen with a new Atwood 6 gal gas and electric water heater. I took a number of pics to share.
The Bowen door is in good condition and so to keep the 'vintage' look on the '66 Trade Wind I want to adapt it to the Atwood. But with the summer camping season rapidly approaching I decided to make this installation with the door that comes with the new Atwood. However, I will make 'adjusments' during the installation to eventually replace the new door later. With no shop manual available removing the Bowen was a small challenge. I thought after disconnecting the plumbing it should pull straight out. It did slide out a few inches before hanging up on 'something'. It was wedged against the grey drain from the galley because when Airstream originally installed it they made room for that drain by denting the side and back of the WH jacket. (The jacket is an aluminum housing that contains the insulation). The 'denting' was crudely made with a hammer for I saw the hammer impressions in the aluminum. I finally found that I needed to twist the WH back and forth so I had to remove the front fascia and as much of the chimney as I could. When the WH was finally free I discovered that is was anchored on it's bottom to the coach floor with a headed pin that slipped into a slotted plate mounted to the floor.
Name:	Airstream - New water heater install 6-07 006.jpg
ID:	46705   Click image for larger version
Name:	Airstream - New water heater install 6-07 005.jpg
Name:	Airstream - New water heater install 6-07 007.jpg
ID:	46707   Click image for larger version
Name:	Airstream - New water heater install 6-07 011.jpg
Name:	Airstream - New water heater install 6-07 012.jpg
ID:	46709   Click image for larger version
Name:	Airstream - New water heater install 6-07 013.jpg
Name:	Airstream - New water heater install 6-07 014.jpg
Neil and Lynn Holman
FreshAir #12407
Avatar;
Casini Ranch Rally
April 2008
1966 Trade Wind
455 cid
Old 10-08-2007, 12:47 AM   #2
FreshAir's Avatar
Airstream Registry
Bowen Out Atwood IN; Part 2
The new Atwood is a little smaller than the Bowen. However, I needed to raise the base that the Atwood would rest on by about two and a quarter inches so that the eventual old door would be at it's original height to the coach side. As it turned out the Atwood door looks better at the elevated height. Before reinstalling the original door FRAME I needed to trim and add side fillers (Atwood is narrower). One view shows the prepped plumbing. I staid with the copper plumbing for now (camping season is rapidly approaching remember) but I use Shark Bite connectors and Pex to the new WH. The Shark Bite connectors were VERY helpfull in connecting this plumbing it VERY limited work space. I had to make the connections with one hand. The additional plumbing on the back of the Atwood is for the winterizing bypass. The wires you see is the electric heater portion. The switch for this is located there but I did not wish o have to reach down through the floor of the bathroom closet to activate it so I moved that operation to the wall in he bathroom. I glued a lighted (lit when on) rocker switch into a switch plate that matches the nearby plug plate. The Atwood door is white, however, even though it is temporary I repainted it silver. Actually it does not look all that bad. It may be awhile before I re-adapt the old door. What do you think?
Oh, yes I cauked the flashing and water heater with rope caulk the vulkem for good measure.
Name:	Airstream - New water heater install 6-07 026.jpg
ID:	46717   Click image for larger version
Name:	Airstream - New water heater install 6-07 023.jpg
Name:	Airstream - New water heater install 6-07 030.jpg
ID:	46719   Click image for larger version
Name:	Airstream - New water heater install 6-07 031.jpg
Name:	Airstream - New water heater install 6-07 022.jpg
ID:	46721   Click image for larger version
Name:	Airstream - New water heater install 6-07 021.jpg
Name:	Airstream - New water heater install 6-07 035.jpg
ID:	46723   Click image for larger version
Name:	Airstream - New water heater install 6-07 034.jpg
Name:	Airstream - New water heater install 6-07.jpg
FreshAir #12407
Avatar;
Casini Ranch Rally
April 2008
1966 Trade Wind
455 cid
Old 10-08-2007, 10:05 AM   #3
cameront120's Avatar
Profile:  1972 25' Tradewind
Fantastic! Was it difficult to do the wiring? I'm not knowledgeable bout electricity and would probably have to bring in an electrician for that part of it. Also, was the LP gas connection soldered, or is there some other form of connection used these days?
Thanks so much for posting these. Very helpfull!
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 10-08-2007, 10:21 AM   #4
Boondocker's Avatar
Profile:  1968 24' Tradewind
on the road , walking to and fro about the earth
Airstream Registry
Send a message via Yahoo to Boondocker
Great post! I have a water heater that has been sitting forever because I havent worked up the gumption to deal with it. This helps. By the way, did I see somewhere a comment about not using PEX within a foot of a water heater?
Rodney
Visit my photography page
or my travel site: theboondocker (new) or the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 10-08-2007, 08:48 PM   #5
FreshAir's Avatar
Airstream Registry
I used the same LP connection that served the old Bowen. Only thing necessary to do was re-route the copper line back a few inches.
FreshAir #12407
Avatar;
Casini Ranch Rally
April 2008
1966 Trade Wind
455 cid
Old 10-08-2007, 08:55 PM   #6
FreshAir's Avatar
Airstream Registry
Hmmmm...have not heard that one. I suppose the suggested danger may be excessive heat to the PEX. One of the PEX tubes supplies HOT water so that can't be a problem. The gas burner and exhaust is toward the front of the WH so that can't be it. The WH is insulated and I have not noticed any appreciable heat build up in the closet above. Obviously I want to be alerted to any such dangers so I will monitor it.
FreshAir #12407
Avatar;
Casini Ranch Rally
April 2008
1966 Trade Wind
455 cid
Old 10-08-2007, 08:59 PM   #7
Boondocker's Avatar
Airstream Registry
I want to say the idea was that the pipe might be hotter than the water and transfer that to the PEX, not sure and it might be bogus anyway. Let me know what you find, I would prefer to got straight to PEX.
Rodney
My Blog
Old 11-18-2007, 10:22 AM   #8
Profile:  1964 19' Globetrotter
palo alto , California
Send a message via AIM to lesliedow Send a message via Yahoo to lesliedow
Similar Bowen-> Atwood using PEX
We just finished the same type of restoration- replacing an old bowen with a new atwood and also used PEX. I decided to keep the external cover from the Bowen, so we did a bit more on the surround and shroud cover.
I have posted most of the work on my blog
www.atfore.com
I looked into the issues around using hot water and PEX. I was assured by the manufacturer, a master plumber I know and the california codes that PEX is fine for hot water right out of a heater. We also used Sharkbite quick release fittings and I love them. Most definitely recommend.
Leslie Dow
www.atfore.com
Everything silver, modern, shiny and organized
1964 Globetrotter
KG6HSG
lesliedow is offline   Reply With Quote
Old 11-18-2007, 09:12 PM   #9
FreshAir's Avatar
Airstream Registry
www.atfore.com
Leslie Dow
Looks like a good job. As I wrote in the begining of this thread I want to adapt the old Bowen cover the way you indicated. My problem is I have too many projects going..Trade Wind and home maintainence. I have been retired more than a year and I am wondering how I ever had time for a job! Thanks for posting your progress.
FreshAir #12407
Avatar;
Casini Ranch Rally
April 2008
1966 Trade Wind
455 cid
Old 08-08-2008, 01:41 PM   #10
bredlo's Avatar
Profile:  1962 19' Globetrotter
Evanston , Illinois
Send a message via AIM to bredlo
8 months later...
I'm in the middle of replacing my Bowen as well (on a '62 GlobeTrotter) and am stuck in the process of pulling out the old one. I detached the one hex nut I could find on a brass pipe leading into the on/off dial, but have seemingly run out of things to disconnect.
The photos above are great, but it's this process of disconnecting everything where I must be missing something... here's where I'm at:
ID:	65314   Click image for larger version
Brad Abridged
bredlo is offline   Reply With Quote
Old 08-08-2008, 01:56 PM   #11
Profile:
Would like the covers
Bredlo,
If you do not plan to use the covers around the old Bowen waterheater, I'd like to have them. Any chance of getting them?
Paul Waddell
Region 2 VAC Guy
WDCU "Past Prez" (In the words of Richard Nixon "You won't have me to kick around anymore!")
rideair is offline   Reply With Quote
Old 08-08-2008, 02:02 PM   #12
bredlo's Avatar
Evanston , Illinois
Do appreciate the interest Paul, but no - gonna try and retrofit the old cover. Mine is a little banged up anyhow.
If you can't find one out there and are feeling pretty ambitious, check out these instructions for building your own brad new replacement Bowen heater cover:
Restoration Topics - HW Heater Covers
Brad Abridged
Old 08-08-2008, 02:46 PM   #13
bredlo's Avatar
Evanston , Illinois
30 minutes later...
Well, I've dug around outside the closet, under the bed and everywhere else there was a pipe or tube leading to this water heater. *Everything's* disconnected. It just simply won't budge, even when I'm really giving it a good kick.
2 possible reasons?
1. The outside topmost piece of trim is still being held on by two flathead screws, which I can't remove because the "chimney" is in the way.
2. That cleat at the bottom of post no. 1 in this thread... I don't see how that could be, though as I can't lift or pull the main tub back - the faceplate is completely flush with the outer skin, as it always appeared.
What do you think?
Brad Abridged
Old 08-08-2008, 04:06 PM   #14
modarch's Avatar
Profile:  1967 17' Caravel
Memphis , Tennessee
Brad-
When I removed my Bowen I had to drill a few larger holes in the "chimney" to access the screws. I was having the same problem you were having- couldn't get to the last few screws!
modarch is offline   Reply With Quote
Bowen or Atwood Sundance Water Heaters, Filters & Pumps 2 07-11-2007 04:22 PM
Bowen W/H Parts needed Shacksman WBCCI Forum 0 06-24-2006 10:31 PM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 06:10 PM
New Atwood water heater old Bowen door vent problem 63air Electrical - Systems, Generators, Batteries & Solar 0 08-22-2005 02:56 PM
Atwood Bowen anode rod? Moonshot Water Heaters, Filters & Pumps 3 11-11-2003 07:37 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
