Old 06-09-2010, 04:37 PM   #1
St. Petersburg , Florida
6 gallon water heater?
We re looking at smaller used Airstream trailers which are not self-contained.
If we do a full hookup in an RV park how do we shower with a 6 gallon water heater?
It's what most of the smaller units have.
Old Cracker
Old Cracker is offline   Reply With Quote
Old 06-09-2010, 04:45 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
You take a Navy shower. Wet down, turn off water, soap or shampoo up, turn on water to rinse. Done properly, you'll have plenty of hot water with a 6 gal water heater, still get clean, and use 1 to 1.5 gals of water total. Most RV showers have a shut off right on the shower head so you're not changing the hot and cold water valve settings.
Chris
Chris
Old 06-09-2010, 04:54 PM   #3
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
Just like Chris said. I turn ours up a to hot for a shower, so you need less hot and more cold. It really is a amazing how much you can get out of 6 gallons. However, if you use 50 gallons at home and you go through that, you may need to look at continuous hot water heater. It heats as you go so you never run out, they work on LP gas. Some are very expensive Tim on www.thevap.com has one and loves it but they run about $1000-1500. But I think are cheaper options out there.
My wife loves long showers and has never had a problem with the 6 gal. We did not have a shutoff on the shower head so I went to Lowes and bought parts to use a gate value and it works great. I have never run out of hot water running the water the entire shower. But mine at home are only 3-4 minutes.
nick6930 is offline   Reply With Quote
Old 06-09-2010, 06:53 PM   #4
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
If you opt to get on demand heater or even a larger (10 gal) tank, Think about water storage. Where will you get/store all of that fresh water? Where will it go after you used it for 3 seconds?
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 06-10-2010, 06:05 AM   #5
6 gallon tank
Thanks to all. It's what I thought:-)
Water wood rot under toilet and water heater! Mrcrowley General Interior Topics 4 12-01-2008 02:34 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Water heater & fresh water capacity ESCAPE POD Water Heaters, Filters & Pumps 5 11-14-2007 04:14 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
