Old 05-05-2014, 08:12 PM   #15
1964 17' Bambi II
Shreveport , Louisiana
Originally Posted by HiHoAgRV View Post
I have the original water heater in my '63. Like yours, it had some issues with the inlet and outlet threads, I also pressure tested, checked the gas side and it works great.
If you DO decide to replace it, I've seen where folks remove the sheet metal from the Bowen, including the flat part with all of the mounting holes and install an Atwood/surburban in that metal. Do some searching here on the forum, I'm sure you will find some neat ideas!
Congrats on the new 'Stream...
I have had the tank under pressure now at 65 psi.
For eight hours.
scwhite54 is offline   Reply With Quote
Old 05-05-2014, 08:18 PM   #16
1964 17' Bambi II
Originally Posted by Jammer View Post
No reason to run it any higher than the relief valve rating.
I haven't heard of anyone retrofitting electronic controls. Not saying it can't be done. Photos and description would be great since me and many others might attempt it. I have a 1973 mobil-temp water heater and am trying to decide what to do with it.
Ok I will try to post some photos .
Old 05-05-2014, 09:06 PM   #17
1964 17' Bambi II
I have not figured out how to post photos
Yet but I am working on it .
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
Repairing 50 year old Bowen water heater 61 Streamy Water Heaters, Filters & Pumps 2 09-12-2012 07:09 PM
40 year old water heater Aluminati Water Heaters, Filters & Pumps 13 11-28-2007 05:44 AM
Engine/Year Trans/Year Matrix ViewRVs Mechanics Corner - Engines, Transmission & More... 36 10-23-2005 07:40 PM
40+ year old heater 59toaster Furnaces, Heaters, Fireplaces & Air Conditioning 6 09-08-2003 06:35 PM
