After all these months we finally have a plan that is coming together but not quite yet. Bathtub has to be sealed in place and the bath sink needs plumbing (both no brainers) and I moved the vent to the bathroom to allow more room for sitting on the throne. Our 19" foot Globetrotters will understand what I mean. I will show how the new box fits over the hot water heater and gives us plenty more room to move. Frig is in (I will show all later) for now... we just brought the Bean home to start the completion. Hope you like it.
"rivit,rivit" |
11-11-2009, 10:05 PM | #45 |
If you run your fridge on propane, I hope you're not leaving the left side of the fridge cavity open to the sink plumbing, for two reasons. First, the fridge works only if the space behind it acts like a chimney, so it can only be open at the bottom and top. Second, the fridge flame can produce CO, so you want to make sure it goes out the top of the "chimney" and not into the living space.
Zep
Zep@Charmedquark.net |
11-16-2009, 09:58 AM | #46 |
USS REQUIN 481
Cool Beans
Hey Zepdawg,
I did not know that. So I understand you say: The frig will only work if it is closed off on either side like a chimney not allowing venting from either side. That is sure enough a big deal! What will happen? Frig won't work? Or not work properly? I don't mind taking it back out and closing off the sides. I removed the Catalitic Space heater too and left that vent open too. I thought I might use it later for a space ventalator fan for removing smells from cooking or whatever. I can easily close it off from the outside and recaulk. Thanks for your caution!
"rivit,rivit" |
11-16-2009, 11:08 AM | #47 |
Oops. If you don't have a good chimney, the fridge still 'works,' but not as efficiently. In really hot weather it may not seem to work at all. What you need to do is encourage vertical air flow in the 'chimney.' So you want the inlet below the fins and the outlet above them. This increases the efficiency of the fins on the back of the fridge. This is true for both propane and electrical operation.
Some of the smaller Airstreams, where an under counter fridge is also under a window, have the outlet right at the top of the fridge. This seems to work, but it doesn't give as good a chimney effect as having the outlet up another two feet or so. If the sides are open, you risk CO getting inside and killing you. So, all around, making a good airtight chimney is important. Zep
11-23-2009, 07:32 AM | #48 |
USS REQUIN 481
Refrigerator Vent
Zep, I checked the space out under the counter and see I have a perfect vertical space between sink and frig to do the job. When I removed all the cabinets we did have a good bit of aluminum shrowds blocking off the entire wall beside and on top of the frig. My cabinet maker side I had plenty of ventallation and we let it go. But now I know why and will take measures to do a proper job of it. It makes sence too! Now it's onto finishing up that frig problem and then start the bath sink install.
Happy Thanks Giving!
"rivit,rivit" |
11-23-2009, 10:09 AM | #49 |
1977 27' Overlander
1973 27' Overlander 1963 19' Globetrotter Naples , Florida Join Date: Nov 2007
I have heard of someone showing how to build a new water heater cover for the Bowen,does anyone have that link? Dave
11-23-2009, 01:15 PM | #50 | |
2021 27' Globetrotter Gulfport , Mississippi Join Date: Mar 2006
Images: 35
I this the link that you were thinking about? Restoration Topics - HW Heater Covers I don't think it shows a new water heater being used with an old cover.
Rick--Foley RV Center www.airstreamofmississippi.com WBCCI #9275 TAC #MS-5 AIR #11800 |
11-24-2009, 11:50 AM | #51 | |
1977 27' Overlander
HW heater remake
11-24-2009, 01:00 PM | #52 |
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix , Arizona Join Date: Feb 2002
Images: 40
Here's a couple of pix that were posted elsewhere here on the forums. Wish I could give credit to the installer / fabricator as it is an excellent job and something I plan to do this spring. Still need the 'upper close out plate' but I'm sure it will turn up soon. I have a bit of reworking of the lower perforated section but the rest of the cover is in great shape.
Kudos to the originator of these photos. Brad FF
4CU 2699 / AIR 10 / TAC AZ-1 I'm haunted by aluminum. Charter Member of the 4 Corners Unit. |
02-13-2010, 10:20 PM | #53 | |
In the meantime, Area63 in southern California did a wonderful installation of the replacement cover this past fall, which has served its purpose well until I can get the Bowen retrofitted.
Brad |
02-14-2010, 07:51 AM | #54 | |
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!" '64 Safari Resoration Blog ("May"): https://ts8501.blogspot.com/ TAC MN-6 WBCCI/VAC 11736 AIR 25979 |
04-11-2010, 06:22 PM | #55 |
This is a great thread and a huge help. We want to replace our old, round bowen but leave the exterior vent trim, and I think I'm well on my way to understanding how to do it, from all you guys. Thanks
Wherever you go, there you are |
04-12-2010, 08:10 AM | #56 |
USS REQUIN 481
Globie H2O Heater
Good for you! I cannot say much right now but the exterior cowling looks and works terrific for me.
It was a rocky start for sure but I am pleased with the results now. Cleaned up real nice with alumibrite acid bath too. More later, I am here for you if you need photos or any help deciding. I have the finished inside to show too. Later,
"rivit,rivit" |
04-12-2010, 12:51 PM | #57 |
Thanks Paris, that is awesome. It's a huge help- the project is kind of daunting, but I'll be in touch.
Peter
Tags |
1963 |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Bowen water heater door with newer suburban water heater | durans54 | Water Heaters, Filters & Pumps | 37 | 11-19-2008 07:17 AM |
1963 Globetrotter | 65CV | 1960 - 1964 Globetrotter | 16 | 03-19-2008 05:27 AM |
Newbe 1963 Globetrotter basket case | Wild Horse | Member Introductions | 9 | 01-28-2008 10:41 PM |
Sewage/Termination Cap 1963 Globetrotter | ShinyTiny | Waste Systems, Tanks & Totes | 7 | 03-09-2005 07:33 PM |
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor | Uncle_Phil | Plumbing - Systems & Fixtures | 3 | 08-09-2002 06:59 PM |
Featured Campgrounds |
