Old 09-04-2010, 03:48 PM   #1
1973 Argosy 26
Centerville , Indiana
12 V water pump too loud
Our 26' Argosy needed the 12 V pump replaced. We got a surflo (proper size) The thing made so much noise we returned it, thinking it was defective but the second one is as bad. When the water is turned on in the kitchen the sound is OK but when you turn the water (both hot and cold) in the bathroom (in Back) this is very loud. We have check for viberation in the lines to make sure they they are not viberating, put the pump on foam padding but still have the very loud pump.
Can anyone give me ideas as to what the cause is?
Hook Shot is offline   Reply With Quote
Old 09-04-2010, 05:25 PM   #2
holden beach , North Carolina
Send a message via MSN to Tom-Mc
water pump
I have found that the suction line need to be larger so the pump want strain. Hope this helps it did for me.
Tom-Mc is offline   Reply With Quote
Old 09-04-2010, 06:04 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
The pump on my boat normal quiet gets very noisy when water tank is empty, so Tom, might be right that pump is working hard to get water, I would check to see if the lines are clear, you can blow back to the water storage tank to see if you have a clog or crimped pipe.
Old 09-04-2010, 06:36 PM   #4
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
What model Shurflo pump did you try? I was thinking of replacing my old 2088 modle with the Shurflo Revolution 4008, they advertise it as exceptionally quiet.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 09-04-2010, 07:36 PM   #5
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
I had the same problem with our 22 Sport FB, I replaced the outlet piece of hard plastic with a 20 in piece of sink hose with female connector on both ends. In the sureflow manual it says that the outlet should be plumbed with a flexible hose to allow for water hammer.
Castaway is offline   Reply With Quote
2008 17' Safari Sport Loud Water Pump Dale Monroe 2008 Safari SE 5 08-22-2010 07:57 PM
Loud water pump quiets down ESCAPE POD Water Heaters, Filters & Pumps 3 03-02-2010 05:28 PM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
