Old 06-09-2014, 12:41 AM   #1
thinktankair's Avatar
1961 16' Bambi
grass valley , California
Wobbly toilet
Wobbly toilet in my 1961 bambi. Solutions?
thinktankair is offline   Reply With Quote
Old 06-09-2014, 04:55 AM   #2
SteveH's Avatar
Common Sense , Texas
They are bolted down to the floor. Have you tried tightening the bolts?
Regards,
Steve
Old 06-09-2014, 08:33 AM   #3
1961 16' Bambi
I had to replace the metal flange with a plastic one. I have tightened the bolts all the way. The base doesn't have complete contact with the floor.
Old 06-09-2014, 08:45 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Check that the flange is not sitting above the floor and that the floor is level.
Also check that the floor material is not soft from rot and is the point of movement
2004 Excursion 4x4
Old 06-09-2014, 08:57 AM   #5
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
If the flange is not contacting the floor it will wobble. Solution is to either insert washers or spacers between the flange and the floor to make sure the flange and the floor become "one", after after firmly tightening. As said before by HowieE No Rot!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 06-09-2014, 01:47 PM   #6
1961 16' Bambi
Thanks everyone. All new wood in the entire area, so no rot! I like the spacer idea - I can pick up some plastic ones at home depot so they won't rot.
Wobbly steel over water tank usuallyalex Fresh Water Systems 8 09-03-2013 02:23 PM
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 06:12 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Wobbly lug nuts Gene Wheels, Hubs & Bearings 16 05-16-2009 07:27 PM
Wobbly dinette table flyfishfred Cabinets, Counter Tops & Furnishings 4 01-21-2008 10:19 AM
