Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 10-23-2010, 09:49 AM   #1
Harleyjohn's Avatar
1992 33' Land Yacht
Wisconsin Dells , Wisconsin
WINTERIZING ISSUES-Black "ink" stuff
HELP!
I recently (May '10) bought a '92 LY (33') and began winterizing it by attaching an air supply (35psi) to the city connection. After alternating opening the water taps, shower, lav and sink, I began getting very black colored fluid from all taps. It didn't have any noticable smell but flowed so much that i re-connected the city (home) water to fill the lines and flush again. I repeated the air flush and again found the black ink.
I frequently checked my air supply, an 8 gal compressor for liquid and found none.
Any ideas????
John
New Member, Air#45995
WBCCI
1SGT, US Army
Retired
Harleyjohn is offline   Reply With Quote
Old 10-23-2010, 09:53 AM   #2
Harleyjohn's Avatar
1992 33' Land Yacht
I also should state that this is my first attempt at winterizing the LY. I also need to figure out how to drain the toilet and flush the water lines with rv anti-freeze. The area at the water pump is v. crowded any help on getting the pink stuff into the lines?
John
WBCCI
1SGT, US Army
Retired
Old 10-23-2010, 10:38 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Hi John. Wow! I wonder if there would be enough slime on the waterline walls to produce this much color? Putting air in at the city connection shouldn't be generating any output from the fresh water tank. Have you been using the fresh water tank? Has that water looked okay?
Maybe the PO wasn't using the fresh tank & line sanitizing method written in the manual. This method with dilute bleach could eventually clean up waterlines. I was seeing some red algae on a white plastic part in my kitchen faucet -- two bleach treatments and it is still there. I'll keep at it...
But I'm amazed you're seeing so much black. My old Argosy tank was translucent plastic under the front gaucho. Some light got in there and generated a lot of green algae. That took removing the tank and some fairly aggressive treatment before I got it under control.
5 meter Langford Nahanni
Old 10-23-2010, 10:40 AM   #4
To get RV antifreeze into your lines, most people use a bypass valve and flexible tubing installed on the fresh water tank side of the water pump. See the first thread here -- Winterizing, Storage, Carports & Covers - Airstream Forums
Old 10-23-2010, 11:50 AM   #5
Originally Posted by Harleyjohn View Post
HELP!
Any ideas????
That black stuff, is from the water filter cartridge that has broken down.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-24-2010, 08:08 AM   #6
Harleyjohn's Avatar
1992 33' Land Yacht
THANKS Andy, I didn't know I had a water filter! I'll look, but don't remember seeing one under the double bed. I saw a small "somethnig" just ahead of the pump, could that be it?
John
WBCCI
1SGT, US Army
Retired
Old 10-24-2010, 08:27 AM   #7
Could be under the galley cabinet.
I should have said water purifier.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-24-2010, 09:40 AM   #8
Ag&Au's Avatar
Port Orchard , Washington
HELP!
Any ideas????
Since it only happens when the air compressor is attached, it is possible that your air hose has lubricant from the air compressor in it or that the hose is old and chemically breaking down.
Good luck,
Ken
Old 10-24-2010, 11:59 AM   #9
Harleyjohn's Avatar
1992 33' Land Yacht
Thanks guys! Think I'll remove the purifier from under the galley and get a new air hose and do this again!. I assume that since I don't have the manual for the purifier I'll be able to bypass it with the cartridge out.
John
WBCCI
1SGT, US Army
Retired
Infamous Suburb.NT-22 "recall" furnace issues! fotochop Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-22-2012 07:42 PM
Looking for a "wand thingy" to rinse the black tank. memgrove2000 Waste Systems, Tanks & Totes 7 07-05-2009 09:37 PM
"gate" to black tank from toilet won't close jeff&jess Waste Systems, Tanks & Totes 9 06-14-2006 09:25 PM
"Stuff" on Master Cylinder swebster Mechanics Corner - Engines, Transmission & More... 24 09-19-2005 06:25 PM
