Old 05-06-2009, 08:36 PM   #1
1973 25' Tradewind
Bellingham , Washington
Where does my gray water go?
I have a 73' Trade Wind. I have figured out how to dump my fresh water tank, and black water tank. I was told there is no gray water tank, so how do I dump my gray water? Where and how does it exit the system? I have 2 exit ports for waste, one under the toilet and one under the shower behind the port side tire. Thanks for the help. Finn
Finn M is offline   Reply With Quote
Old 05-06-2009, 09:03 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Fill up the kitchen sink, pull the stopper, and see where the water drains out under the trailer? There is no gray water tank, soit should come out of the same outlet where the black water will drain when you pull open the black water valve.
Old 05-06-2009, 09:07 PM   #3
cameront120's Avatar
1972 25' Tradewind
The grey water drains out of the same hole that you black water drains from. You can attach a garden hose and direct it to a temporary holding tank, if you like. It will freely drain from this outlet without having to release the black water. It's a drain within a drain, if you will. If you block the drain, the grey water will back up into your wet bath or tub, depending on what bathroom layout you have.
North Vancouver, BC
Old 05-07-2009, 08:23 AM   #4
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
You will need to get what they call a "blueboy" drain the gray water into it and then dump it at a legal dump station.
We have a 72 tradewind and have added a gray water tank and new dump valves so we can dump the gray water and black waste tanks separately.
Annette
P.S. You sound like me last July when we bought our Airstream, had no idea about tanks, didn't even know we had a black water one. We've learned a lot since then. Keep reading.
ID:	79855   Click image for larger version
bullydogsmom is offline   Reply With Quote
Black Water/Gray Water TimeOut Plumbing - Systems & Fixtures 13 10-18-2015 07:00 AM
Gray water Tank CJ of Okla Waste Systems, Tanks & Totes 10 08-09-2008 10:01 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
gray water handling darin Waste Systems, Tanks & Totes 2 01-08-2004 09:04 PM
Gray water tank Joe62984 Waste Systems, Tanks & Totes 12 01-02-2004 07:45 PM
