Old 08-24-2011, 12:47 PM   #1
KerriO's Avatar
2008 27' International CCD FB
Bay Area , California
Where are the vent pipes? (AKA: Things That Should Be in the Manual)
So I'm thinking we have an obstructed vent pipe for our grey water tank. The monitor went from nearly empty to flashing red overnight last night, and when I looked down the shower drain, I could see standing water pretty high up. No way we used that much! We didn't even use the shower.
We drained some into a five-gallon tub. It filled the tub, but then turned to a trickle after that (with the tank still mostly full).
I can't find any info on where to look for the vents, or what they even look like. The manual doesn't even mention them.
I have a 2008 International 27FB.
KerriO is offline   Reply With Quote
Old 08-24-2011, 12:54 PM   #2
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
There should be water down the shower drain held in the "P" trap. The shower / sink vent in my 2008 safari is under the rear sink, and does not vent thru the roof like the black tank vent.
Is the grey tank monitor working? after draining into the tub, u didn't say hiw big of a tub, it should register on the monitor. Question the monitor if it showed full overnight.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 08-24-2011, 01:07 PM   #3
KerriO's Avatar
Based on what I've read elsewhere on the forum, you can look down the shower drain directly into the tank. This isn't true?
I said the tub was five-gallon. We definitely didn't drain enough to empty the tank before it started trickling.
I would assume that the vent locations might be really different on a 23' vs a 27' FB…
Our monitors are far from accurate, but they generally are *somewhat* in range. EG, if it's red, it might be slightly less than half full; if it's flashing red, it may be nearing full, but not *that* full. I am relatively certain, regardless of what the monitor says, that we've still got water in the tank that didn't drain. For what it's worth, the monitor went from flashing red to solid red after the five-gallon emptying.
Old 08-24-2011, 01:21 PM   #4
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I really think you are looking down at the standing water in the trap. Without a trap, you would be smelling the grey tank, not nearly as potent as the black, but you wouldn't like it. The black and grey tanks should each have a vent pipe to the roof. Do you not see 2 up there? The sinks often have a device that I believe is called a vacuum breaker. It's a 1-way rubber flap that allows the sink to flow freely into the tank.
You can normally look straight into the black tank when you hold the flush valve open on the pot.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 08-24-2011, 01:26 PM   #5
KerriO's Avatar
I was probably misinformed (or I mis-read) about being able to look into the shower drain. Regardless, I still think there's more water to be drained. (And I'm bummed that there's not a simple non-monitor way to check that gray water level!).
I guess we'll need to get the ladder out, because I can't see any vent pipes from here. (I assume their location on the roof would be somewhere directly over the tank's location?). There is something with a conical black plastic cover, that is maybe 8" in diameter, and not very tall. Is that the vent pipe? I just have no idea what I'm supposed to be looking for.
Old 08-24-2011, 01:35 PM   #6
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
That might be it KerriO, or the black tank vent. But they may be tied in line together somewhere.
Yankee's right, may be a vacuum breaker somewhere but not likely in the wall but rather in a cabinet.
Sphere Guy
AIR 50601
Old 08-24-2011, 01:40 PM   #7
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Why Are You Focused on Vent Pipes?
I've read your thread twice, and I can't understand why you are so concerned about your vent pipes. The capacity of your gray water tank is not effected by your vent pipes.
By the way, you cannot see into your gray water holding tank from your shower. As others have mentioned, there is a P-trap that should have water in it even when the gray water holding tank is empty.
Please describe the malfunction you think you are having so we can help.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 08-24-2011, 01:45 PM   #8
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Okay, I Read the Thread Again...
Are you level? If your Airstream is sloped away from the dump valve, you will never attain the nirvana associated with a thorough dump.
Ken L
1966 Tradewind 24
Old 08-24-2011, 01:50 PM   #9
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Check here for photos of the vent pipe aluminum covers that are on the roof Vent pipe cover-aluminum 101158 [101158] - $42.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Vaughan
Old 08-24-2011, 01:51 PM   #10
KerriO's Avatar
Yes we are level. My concern is not the capacity; my concern is that it is not draining well, and I believe it didn't drain completely during the dump we did prior to this "five-gallon" drain (which is why we were surprised by how quickly it filled). When I search the forum, everyone who has draining issues gets the response to check for obstructions in the vents.
ETA (x-posted): Thanks vswinfield — that helps. Don't know why I didn't think of looking up the part!
Old 08-24-2011, 02:05 PM   #11
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Generally Speaking...
... the large diameter of the dump valve itself should allow the holding tanks to "self vent" when you open the dump valves. The vent pipes themselves allow sinks and shower to drain by eliminating vacuum in the drain lines to the holding tank. There may be exceptions, but this is generally how drains and vent pipes and holding tanks work. Any slope away from the dump valve will keep your holding tanks from draining completely. Do you have a torpedo level? Check your level side-to-side.
Ken L
1966 Tradewind 24
Old 08-24-2011, 02:18 PM   #12
aftermath's Avatar
Spokane , Washington
Just a thought
Are you sure the gray water monitor is working? One way to check is to run water in the sink until you see the water actually backing up in the shower. At this point you will know that your tank is full.
Would it be possible that you are getting a full reading when the gray tank is far from full. You said that it was full but "not that full."
I also have a vent under the sink in my 2006 25 FB that does not exit the trailer. A clogged vent might slow the draining of the tank but I would check to see if the tank was indeed full before I did anything else. There is a way to recalibrate the monitors if this is a problem.
aftermath is offline   Reply With Quote
Old 08-24-2011, 02:53 PM   #13
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
It only took us three days of (injudicious) water use to fill the gray tank two weeks ago to the point at which it backed up into the shower. We don't often "camp" without FHU, so didn't control our sink and shower water use properly for a three-day stay. Interestingly, the monitor never showed red even when at high water. It also shows 3/4 full after about a day in camp, but that's not right either. Hmm . . .
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 08-24-2011, 03:59 PM   #14
Wise Elder
Jammer's Avatar
2010 30' Classic
The holding tank monitors are rarely accurate and should not be counted upon to provide reliable results for anything as important as troubleshooting. The best you can hope for with them is that they'll show empty when the tank is empty and full when it's overflowing. Anything in between is a guess.
As an experiment you may wish to run the shower until your greywater tank is full as indicated by a slight backup of water into the shower area. Then you can determine whether there is really a problem based on the amount of water in or out.
Removing sealant around my vent pipes on a1989 345LE Motorhome. maxr Classic Motorhomes 0 03-22-2011 08:29 PM
Fitting a Nicro vent to the existing Hehr vent Globie64 Roof Vents, Skylights & Fans 8 03-17-2011 02:35 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 04:58 PM
