Old 03-29-2005, 01:53 PM   #1
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
What's in there?
I'm wondering how many Airstream coaches have the boxed-in rear bumper, which, on my rig, is where a big flexible tube is stored. My question is this: Inside the boxed in bumper, there is a sheet steel box that surrounds an insulated fiberglass tank, and the sheet metal has rusted out. I'm thinking of replacing the sheet metal part I can see with sheet aluminum, riveted in place with 3/4" aluminum angles. The fiberglass tank is obviously the black water tank. What holds this in place? At the rear, where the sheet metal has rusted out, there is a piece of plumbers tape which appears to hold up the tank. The plumber's tape is all but rusted out itself. At this point, might the belly pan be holding the tank up? Has anyone seen a great repair for this, and any sort of retrofit for the leaky bumper-box cover?
thanks
Peter
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 03-29-2005, 02:17 PM   #2
AirConditioner's Avatar
'Tanks' A Lot....on the Forum
If it's like mine was, the only thing holding it up substantially was the toilet! Do a search for 'tank repair' or 'black tank' on the forum. There's a number of really detailed repair photos that were very helpful to me. I ended up replacing the steel channels and added a few other brackets and angles. It took me 4 hours, and was not difficult. As you will read, support the tank during the entire process. If you're the least bit handy, you probably can do it. Good luck.
AirConditioner is offline   Reply With Quote
