Old 02-21-2011, 09:38 PM   #1
1966 30' Sovereign
Mount clemens , Michigan
What size tank
What is a good size black tank? I plan on doing an above floor tank and mount a low profile thetford on top. I will probably only be camping on long weekends and there will be 2 adults and 1-2 young children. What is the max height I should go? I will be covering the tank with 3/4 plywood. How many gallons do people think I should use. Please don't say "as big as you can". I really want to know what size would be enough. 10 gallons seems small but maybe i'm wrong. Thanks.
Brianv512 is offline   Reply With Quote
Old 02-21-2011, 09:44 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My 75 TW has a 12 gallon tank. Four days is about the max for two of us.
Richard
Old 02-21-2011, 10:09 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We have 10 gallon black tanks in each of our trailers. It's enough for 2 adults for about 4 days. BUT, we don't have kids and we do conserve water when we can...the tank fills with paper & water more than "waste" - if you really want to save room - be mindful of those and you'll be in good shape.
Usually, most people will use more gray water than black...but with a '66 you don't have a gray tank to fill unless you plan on adding one.
Good luck in whatever you decide to do ~
Shari
New Slant on Tank Sensor Cleaning... Mexray Waste Systems, Tanks & Totes 5 01-30-2011 01:07 PM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 04:10 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
waterlines size qc1500 Fresh Water Systems 8 01-11-2011 06:04 PM
