Old 09-23-2004, 08:17 AM   #1
M&M CAPECOD's Avatar
2010 27' FB Classic
Cape Cod , USA
Images: 21
Question What size is it 54 or 60 gallon (FW tank)
I'm planning on cleaning the fresh water tank on our '02 28' Classis today. I've read up on the procedure and I'm all set to go except I don't know which is the correct size of our tank. the specs in the book say a 54 gallon tank but on the closet door it says it is a 60 gallon tank. Does anyone know which is correct. I think I'll go ahead and clean it as if it's a 60 gallon but would like to know which it is.
One other quick question, do any of you use a deodorizer in your tank or something else? I've seen products advertised for removing soap scum build-up and the like. Is this really an issue? If you do, what quantity and how frequently?
Thanks in advance for your help
Whatever you are be a good one....'Abraham Lincoln'
WBCCI #9204, Region 1, 1st VP NEU
TAC #MA-4
M&M CAPECOD is offline   Reply With Quote
Old 09-23-2004, 05:29 PM   #2
Cartoon Character
Porky Pig's Avatar
2004 34' Classic
On The Road , U.S.A.
Your water heater holds the other 6 gallons.
Porky
TrailerGypsies.com
WBCCI #3405 — Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 09-24-2004, 11:32 AM   #3
RivetED's Avatar
North Central , USA
I use an 'enzymatic' sanitizer/deodorizer once a year in the grey tank just 'because' & in the black tank a little more often depending on use or if we 'detect' a odoriferous reason to increase the frequency of treatments! Follow the instructions for '1st/initial treatment' if you don't plan to use it exclusively, we don't & not for combined use with the 'blue' stuff or like!. Can't remember the brand name of the one we just bought at Camping World, but boat supply stores carry it also. At the Cape that would be my 1st stop!
RivetED is offline   Reply With Quote
Our long, long trailer (AKA 19' CCD) crazylev 1997 - 2004 Bambi 60 05-11-2006 12:53 AM
Discovery...Grey Bypass!!! Tank Size?? blrpix Waste Systems, Tanks & Totes 9 08-12-2004 04:08 PM
Size of tank Rysue Waste Systems, Tanks & Totes 0 10-01-2003 11:13 PM
size of gray water tank mtccollins Waste Systems, Tanks & Totes 3 08-09-2003 05:34 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
