Old 12-18-2014, 06:42 PM   #1
1955 30' Liner Commodore Vanderbilt
Linden , Michigan
What is this Black Water Connection called, and where can I find a cap?
What is this type of black water connection called, and where can I find a cap?
StevieB is offline   Reply With Quote
Old 12-18-2014, 06:44 PM   #2
Linden , Michigan
Obviously I need help on "how to post a pic."
Old 12-18-2014, 07:05 PM   #3
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
I'm a little confused are you talking about sewer cap. The cap you remove to connect hose to empty black water tank.
Ron
Ron A is offline   Reply With Quote
Old 12-18-2014, 07:12 PM   #4
Linden , Michigan
Yes, that is correct. I wish I knew how to post a pic. It is for a 63 Bambi.
Old 12-18-2014, 07:36 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
To post a picture, click on "Post Reply" at the lower left of the last comment (not the "Wuick Reply" window). That will give you a posting window..scroll down below the posting window and you'll find "Manage Attachments"...click on that and you'll get a separate pop-up window through which you locate the picture on your hard drive and upload it... You can also type text in the posting window...once you are finished uploading the picture and adding whatever text you want to accompany it, post the comment...the picture should appear in the completed post (..it doesn't appear in the posting window...) You can post up to 10 pictures in a single posting in batches of 4 + 4 + 2. Hope this gets you there!
TB & Greg and Abbey Schnauzer
#3954
Old 12-18-2014, 07:48 PM   #6
Ron A's Avatar
Any RV shop and often you can find them at Walmart, go to their automotive/RV area in store.
Ron
Old 12-18-2014, 08:01 PM   #7
Ron A's Avatar
Waste Valve Termination Cap
Ron
Old 12-18-2014, 09:03 PM   #8
1974 Argosy 20
Kooskia , Idaho
Didn't the early 60's Airstreams use a metal dump valve and metal termination system? I seem to recall those caps were called "frying pans" and are made of unubtanioum (no longer made, and rare). They were solid aluminum.
Somewhere in the mid 60's Airstream went to Thetford plastic waste fittings, which are still available, but not really common anymore. You can still get them on line and at a really well stocked RV store.
I have a vague recollection of someone with the old metal system cutting it off and epoxy bonding a new Thetford to the end of the pipe. If I were doing that today, I would probably use a Valtera which is the common one these days.
You might even be able to join the old metal pipe to plastic with there clamp type rubber couplers you can find at the Home Depot/Lowe's type stores.
Old 12-19-2014, 03:56 AM   #9
Linden , Michigan
Pics
Thanks to TBRich for schooling me! Attached are a couple of pics.
ID:	228877   Click image for larger version
Old 12-19-2014, 05:44 AM   #10
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
"Modern" sewer line fittings come from one of two manufacturers--Thetford and Valterra. Our '66 model has a Thetford connector.
These days most sewer hoses have Valterra connectors and one has to use an adapter (readily available at RV stores) to connect.
I don't know if a cap from either of these manufacturers would fit your Airstream. You might consider giving a Thetford cap a try.
Old 12-19-2014, 02:42 PM   #11
1974 Argosy 20
Kooskia , Idaho
That is the old metal fitting and uses the "frying pan" cover. I don't think that any currently available Thetford or Valtura will fit it. Those with old original trailers may be better equipped to post an answer than I am about if the "frying pan" caps are available anymore from any source. Also if they are not, what to do about it, that is what workaround solutions are available.
Old 12-19-2014, 03:52 PM   #12
Southwestern , Ohio
StevieB,
Oh boy. You do have some work ahead of you.
From about 1960 to 1964 Airstream was still trying to figure out how to handle sewage. Prior to that time trailers didn't have black tanks. The toilet either flushed to a sewer connection or a "gopher hole".
Our first Airstream was a 1960 Pacer. It used a modified brass wedge gate valve for the dump valve and the dump port was plain old Schedule 40 galvanized pipe--no locking pins on the outside.
Since it was just round pipe I found that I could bore out the inside of a modern plastic dump valve adapter for a slip fit on the outside of the pipe, fastening it in place with stainless steel machine screws tapped into the pipe and the whole thing sealed with pipe dope. That worked "OK" as long as we owned the trailer.
That option doesn't seem to be available since you have bayonet locking lugs cast into the outside of your dump port. Vintage Trailer Supply has some advice and conversion components
Waste Valve Adapter for Early 1960s Airstreams
Thetford Valves & Fittings
Here's another reference on replacing everything back to the tank:
Brass Thetford Dump Valves - Vintage Airstream
You're looking at quite a job, but it's worth it, as the old dump system wasn't big enough and the RV industry has learned a lot since it was made.
On the plus side, having done the job, you will be eligible for membership in the exclusive Royal Order of the Black Tank--an organization few have any interest in joining. . .
Nuvite-F is offline   Reply With Quote
Old 12-31-2014, 08:01 AM   #13
Linden , Michigan
Wanted Dead or Alive - 1963 Waste Cap or Hose Connection
Thanks Nuvite-F!
On another note, I was wondering if anyone out there has the original frying pan cap or hose connection for this wedge hook-up, or maybe an adapter system that I could use with a more modern hook-up? I really don't want to join the Royal Order of Black Tank Pooper Scoopers at this time.
StevieB
Old 02-19-2015, 04:30 PM   #14
Linden , Michigan
Does anyone have a "Frying Pan" Cap or the connector for the hose that they may want to part with?
Looking for sewer termination cap. Can only seem to find 3 inch but it seems to take Lafayette Waste Systems, Tanks & Totes 2 12-10-2014 07:30 PM
What is the "rain channel" over windows and doors actually called? Rob&Julie Windows & Screens 3 01-19-2012 07:26 PM
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
What is this thing called and where do I buy a new one? jimmieanna Waste Systems, Tanks & Totes 13 06-20-2011 08:46 PM
the black hole called a closet greenRNtrav. Lights - Interior & Exterior 3 08-02-2009 10:15 AM
