Old 02-19-2015, 05:42 PM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If a Thetford connector won't work.
Before tearing everything apart and upgrading it. I would try a Fernco connector. It would require grinding off the lugs on the existing pipe and providing some sort of support (clamp) system for any ABS or PVC pipe/fittings down stream from the existing pipe.
Since the trailer does not have a blackwater tank. You will either have to be connected to a sewer or use some sort of exterior tank such as a tote.
Old 02-19-2015, 06:56 PM   #16
indy's Avatar
1962 22' Safari
kansas city , Missouri
Images: 22
Homemade frying pan cap
I have run into the same problem, so this is my fix!
indy is offline   Reply With Quote
Old 02-20-2015, 06:10 AM   #17
1955 30' Liner Commodore Vanderbilt
Linden , Michigan
Frying Pan Cap
Very Cool. So, how did you make it?
StevieB is offline   Reply With Quote
Old 02-20-2015, 07:43 AM   #18
indy's Avatar
1962 22' Safari
Images: 22
Homemade cap
First I am retired sheet metal worker, so I had some thick copper sheet about 3/32" thick I cut the collar of the cap first formed it round to fit the needed diameter I then silver soldered the collar and a flat pc. together, next was to cut and grind off the edges making it round then came the brass lugs in the collar I used a couple of air line fittings leftovers, think they were 5/16" dia. Drilled and mounted in place then more silver solder, and then a male brass hose fitting for the hose draining or capping it for travel.
And last I glued a rubber gasket inside of cap, bingo let it flow!
It ain't pretty but it works.
Hope this helps.
I am thinking this is a part I could make and sell? Let me know if you are intersted!
Old 02-20-2015, 08:37 AM   #19
Linden , Michigan
I would be interested. PM me with the pricing.
StevieB
Old 02-20-2015, 09:13 PM   #20
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey Steve,
The Vintage Airstream website has directions for converting to the Valtera valve. Works well for me.
Tim
Beaker63 is offline   Reply With Quote
Old 02-21-2015, 06:23 AM   #21
Linden , Michigan
Thanks Tim, I will have to check this option out too.
Looking for sewer termination cap. Can only seem to find 3 inch but it seems to take Lafayette Waste Systems, Tanks & Totes 2 12-10-2014 07:30 PM
What is the "rain channel" over windows and doors actually called? Rob&Julie Windows & Screens 3 01-19-2012 07:26 PM
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
What is this thing called and where do I buy a new one? jimmieanna Waste Systems, Tanks & Totes 13 06-20-2011 08:46 PM
the black hole called a closet greenRNtrav. Lights - Interior & Exterior 3 08-02-2009 10:15 AM
