Old 11-27-2006, 12:28 PM   #43
cammur's Avatar
Roseville , California
Ten gallon is my limit because of weight and for storage space in the back of the truck. You can not tow the 10-gallon behind a truck, as you can with some of the larger ones (the wheels are too flimsy).
Rarely do you exhaust the black tank, so reserve the blue for gray water. It is is not enough and the dump station is too far away, follow other suggestions on this forum for moving dishwater (etc.) from the sink to the toilet to make use of extra black tank capacity.
You can buy an optional how-full indicator for the blue tank but I found it of no value.
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 11-27-2006, 01:04 PM   #44
Elgin , Texas
Images: 164
I have one of the two wheel 25 gallon BB's, but upgraded the axle and fitted a pair of pneumatic tires (which is nice when it's a long haul to the dump station - quiet, too). Also use a 3" expanding test plug in transit so no chance of leakage. Sorta got to thinking about adding a small 12-volt inline pump that I can power from the trailer umbilical which would allow me to leave the BB up near the front of the trailer by the truck. This would allow me to empty the gray water on a slope if need be, as opposed to having to "find the low spot", or wind my way through trees and whatnot, lugging the full beast all the way. I can just hook the empty tank to the truck, hit the switch, and off she goes.
bake315 is offline   Reply With Quote
Old 03-07-2011, 07:47 AM   #45
audiv8q's Avatar
1986 34.5' Airstream 345
Longview , Washington
Send a message via MSN to audiv8q Send a message via Yahoo to audiv8q Send a message via Skype™ to audiv8q
Originally Posted by clancy_boy View Post
Really - all this discussions on blue boys has me wondering again which size I need. I am looking 4 wheel but all the sizes have very flimsy "axles" and wheel combinations - how long do they last?
Wow...
Next, we'll have to start a "Frame-off blue-boy restoration thread", where we can share tips and tricks about axle replacement, and the best paint to use.
Just a thought...
Cheers!
audiv8q is offline   Reply With Quote
Old 03-07-2011, 08:03 AM   #46
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
FWIW: I have the 32 Gal. Barker. I did upgrade the rear wheels to Pneumatics from Harbor Freight. I simply removed the old wheels (wiggled off the cap that held them on) and the new wheels fit right on the axle. I think tapped the caps back on and they have been fine ever since (of course a washer and cotter pin would be better and it's on my too do list, although the caps have stayed tight). It tows much more nicely without the solid wheels on the back and is not nearly as noisy rolling through campgrounds. I have not upgraded the front wheels at this time. I do use common sense towing it (low speeds and watch out for bumps and potholes). Some places I have to tow it a mile or so each way. BTW I have dumped both grey and (a few times) black tanks (only when absolutely necessary :-0 ). When dumping the black tank I pour some clorox in the tank with a bit of water and leave it in there to swish around. That has seemed to eliminate any odor problems that might occur and it really doesn't seem to be a big deal.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 05-25-2011, 09:39 PM   #47
GAT
Owner Spirit of "76"
GAT's Avatar
1976 31' Sovereign
Ball Ground , Georgia
I am in the market for a tote and have never used one. I will not use it for black water. The only reason my wife will camp with me is she loves the shower and won't use the bath house unless necessary. Generally how many gallons of grey will you use with a fair shower. Will I have to empty after each shower with less then a 25 gallon size. I try to stay at sites with sewage but it's not always possible.
GAT is offline   Reply With Quote
Old 05-26-2011, 05:28 AM   #48
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
I have been trying to polish the classic blue boy I found on ebay. But the compound keeps rubbing holes in the plastic.
Am I on the wrong thread?
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 05-26-2011, 08:22 AM   #49
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by ROBERTSUNRUS View Post
Hi, I don't want to crash your party, but I hope I never have to have one of those things. [Blue waste tank on wheels.] Tanks, but no tanks. Trailer tanks full? Time to move!
Me needer...just a mess waiting to happen.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 05-26-2011, 08:31 AM   #50
Wise Elder
Jammer's Avatar
2010 30' Classic
Figure 2-3 gallons per minute for the shower. Typically 10 gallons for a conservation-minded shower for us although it's possible to get by with much less especially for those with short hair.
Old 05-26-2011, 09:32 AM   #51
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Maybe a bit off topic, and in any case, may not be of any use to you, but here is what I have done.
We very seldom camp without full hookups and so I didn't want to be carrying a blue boy all the time for the few times we would ever need it.
I do find that when we have had to camp without sewer hookup, we only seem to be able to go a couple of days before the gray water backs up into the shower. The black water tank lasts much longer.
So what I did is to get two plastic dish basins that are a perfect fit into our sinks.
When we wash dishes, we can dump the dishwater into to toilet, thus getting much better use out of our two tanks.
In the event that we stiil wind up filling the gray water tank, I bought a sewer outlet cap that has a standard hose connector built in, a short length of hose, and one of those collapsible 5 gallon water containers.
That way, if we were close to filling the gray water tank, i could just dump 5 gallons at a time and easily take it to the dump each trip we make out of the campground. (no, I won't use the five gallon container for drinking water!)
The sewer cap with the hose attached would also allow me to surreptitiously and slowly dump a little a little gray water somewhere under the trailer - but of course, I wouldn't do that!
We tried out the sink basins just last weekend - worked perfectly. We haven't had to use the five gallon container yet
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-26-2011, 05:03 PM   #52
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Brian.
There are some locations that allow you - and want you to for drought reasons - to dump grey water on the ground.
Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 05-26-2011, 05:24 PM   #53
Wingeezer's Avatar
2005 30' Classic
Mike
Just not where I seem to camp I think!
I did meet a guy in Florida with a large motorhome who had installed a small 1/4 line and valve from his sewer outlet pipe near the cap and that lead back to an open end somewhere near his axle at the centre line of his motor home. If he had no sewer hookup and gray water was getting full, he said he would just open the little valve at night time - naughty fellow!
Brian.
2005 Classic 30'
Old 05-27-2011, 04:50 AM   #54
one of those
Gringo's Avatar
Well,I think the phosphates in soaps were good for plant life, too, so dribbling gray water on the ground isn't all that bad a plan as long as it doesn't make a mess and degrade someone else's enjoyment.
Of course, a lot of states recently took phospate based detergents off the shelves.
(Any of you noticed that your home dishwashing machine doesn't seem to clean the plates and pans as good as it did last year? If you're still using Cascade, it's not the same stuff anymore. No more phosphates. Lousy cleaning.)
Old 05-28-2011, 10:31 AM   #55
Thumbs down
Do what the tent'ers do, just toss.
What's the fauna for after all.
PFC
"Tahawus"
RLC
John Prine
Old 05-28-2011, 11:04 AM   #56
JFScheck's Avatar
Rockville , Maryland
Images: 33
When on my property - I will use a long 50 foot hose and dump the grey via one of those "hoses with holes" used for watering - I use Burt Bee's soap products on myself and an organic liquid dish wash so my grey water I feel is safe for the environment - black goes to the public dump site at SteamBoat Lake...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Holding tank valve pull's camphost Waste Systems, Tanks & Totes 3 10-31-2002 11:11 PM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 09:02 AM
Kenny, the city boy PeterH-Airstreamer Off Topic Forum 3 08-05-2002 08:47 AM
Black Tank Flooded Trailer John E Insurance & Claims 3 04-23-2002 09:19 AM
