Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 08-26-2002, 06:46 PM   #1
niftypkg
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Red face What Grey Water Tank??
Don't have one. 1971 International. Grey water outlet is OUTSIDE of dump valve!! Only solution is to open dump valve and let grey water flow into tank,which AS does NOT recomend!! Other wise on ground which no one recomends!!
niftypkg is offline   Reply With Quote
Old 08-26-2002, 06:59 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
What about a "Blue Belly"?
There have been several good threads on this topic:
Grey Water Waste Tanks
Grey Water Tank BIG Question
Where's a good place to buy stuff?
Shari
Old 08-27-2002, 07:03 AM   #3
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
Re: What Grey Water Tank??
The copy of the Manuel on my 68 GT states to cap the outlet and open the dump valve to let the gray water back into the black tank. I do this all the time. Makes dumping the tank a little tricky. I have a cap with a hose connection on it, I have connected a ball valve to the outlet then a hose. Close the dump valve drain the lines, remove the cap attach the slinky and dump. I am in the process of installing a Macerator pump to make it easier
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim, N5TJZ
2005 25' Safari ,AIR# 174
S/V Wandering Spirit
http://airstreamlife.ning.com/profile*/JimClark
Picture Gallery
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 08-27-2002, 07:38 AM   #4
niftypkg
niftypkg's Avatar
Cornville , Arizona
Angry Grey Water Tank
Jim, that's what I have been doing, just don't forget to close the dump valve before removing the cap. Heard about the macerator pump; also heard about a water operated 'sewer solution'. Thank's for the reply.
Old 08-27-2002, 07:53 AM   #5
niftypkg
niftypkg's Avatar
Cornville , Arizona
Unhappy Grey Water Tank
Black/ grey Who cares?? Thanks Shari for the leads, they are very informative. When I bought my trailer hadn't a clue about tanks, It was either a trailer or the Econo lodge{$$$$} That made the decision. But I do miss the maid service! Managed to live without the grey tank. There are plenty of Flying J's.
Old 09-03-2002, 11:24 PM   #6
Rob
Profile:
My 72' had 2 oversized gray tanks added. The original system has been removed. I'm gong to try and go back to original design.
Could you tell me which side the original dump gate and gray water outlet were on.?
Rob
Rob is offline   Reply With Quote
Old 09-04-2002, 07:12 PM   #7
niftypkg
niftypkg's Avatar
Cornville , Arizona
Red face What Grey water tank
Rob, the dump valve in my 1971 27' Int. is on the left side, or road side. The grey water outlet is after the dump valve. Put the cap on the waste system ,open the dump valve and the grey water goes into the black tank.
Tom
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 07:52 AM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
Grey water tank for a 68 Globe Trotter Bryanhu Waste Systems, Tanks & Totes 5 06-26-2003 09:18 AM
No Grey Water Tank????? Anna Waste Systems, Tanks & Totes 16 11-17-2002 07:33 PM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
