Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 08-25-2008, 10:45 AM   #1
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Question What do you do to control the Gray tank odor??
After a few trips out, my gray tank vent is presenting us with a most interesting odor. Most definitely coming from above. I have removed a section of the belly pan to verify no leaks from the tank.
The location of the vent is close to the rear vent, so with the vent open it will on occasion it will waft in, mmmm.
˝ gallon of bleach has helped but not enough to remove the nuisance.
What are you doing to reduce or eliminate this from happening to you?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 08-25-2008, 11:16 AM   #2
mistral blue
Certifiable
mistral blue's Avatar
Profile:  1977 Argosy 24
Beautiful , New England
We usually have the rear Fantastic Fan blowing out, not in.
"IT'S A MAGICAL WORLD, HOBBES, OL' BUDDY... LET'S GO EXPLORING!" ~ CALVIN
mistral blue is offline   Reply With Quote
Old 08-25-2008, 11:20 AM   #3
purman
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
Are you sure it is the grey tank? Has it always done this? Have you change your diet? (just joking)
They do make cleaners for tanks you could try that, clean and sanatize like it was a fresh water tank...
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
'89 Jaguar XJ6
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-25-2008, 11:29 AM   #4
balrgn
balrgn's Avatar
Images: 74
Yeah it's the gray, made the mistake of actually climbing up there (eeewe) 'Matter o fact the black is way better. The blue goo really takes care of it.
Started 3rd time out with this rig. Have not had it long, figure it must have set for years not being used. Tried several cleaners, knocks it down for while then comes back. May mix up come OxiClean and try that.
Man does that stuff activate with bleach, almost blew m'self up last week cleaning something
Member of VAC
www.balrgn.com
Old 08-25-2008, 11:30 AM   #5
Gen Disarray
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
I have treatment that goes in both the black and gray tanks, no smell. I will try and remember to look for the name of it tonight.
Rodney
On a magic carpet ride
Visit my photography page at:http://www.pbase.com/professor_chaos
Gen Disarray is offline   Reply With Quote
Old 08-25-2008, 10:23 PM   #6
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I've had great luck with Odorlos brand, the green stuff. I have had approximately 6 gallons of water in the black tank and 5 gallons in the gray tank for 5 months now with only one 30 gallon treatment to each. I'm not smelling a thing out of the ordinary when I go into the trailer to work on repairs. By the way, the Fantastic Vent Fans are both running on low and both exhausting.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-25-2008, 10:42 PM   #7
TBRich
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
Try using the tank treatment stuff in both the back and grey and see if that helps...you wouldn't think that the grey water would get that rank, but it does... I do this periodically to help it stay "fresh" (as can be expected, anyway)... Also when not traveling, we mke sure the P-traps are filled with water so the odors don't come up through the sinks... Good luck!
TB & Greg...Cockers Annie & Sadie...and Homer the Desert Tortoise
WBCCI Four Corners Unit #3954
AirForums #21900
Please Visit Our...
Décor Site: AZBambi Décors
Old 08-26-2008, 05:52 AM   #8
overlander63
Rivet Masher
overlander63's Avatar
Profile:  L.A., Dammit , California
You can use a cup of clothes soap in the tank, drive it around for a while, dump it, and add some Odorlos to help with the smell.
Old 09-19-2008, 01:21 PM   #9
laverperson
Profile:  2001 25' Safari
surrey , B.C. Canada
grey water tank smell
Howdy folks!,
Having read what there is on this thread about tank odors getting into the trailer still doesn't remove my wondering how it's getting "in" in the first place. The p-traps being full, should prevent tank gasses from entering via the sinks and shower, all of which have automatic vents as well as the common vent going out through the roof. I talked to a fellow from an RV dealer and he suggested that maybe the vent stack going through the roof had settled down below the roof line thus allowing gasses to enter the trailer. I checked that and it wasn't the case. So does anybody have any other ideas as to how the gasses are getting in? I own a 2001 25' Safari, and the only thing I can think of is that the vent stack is located right next to the AC unit and the fumes are entering through it. Is this possible?
Any help would be greatly appreciated.
Art
laverperson is offline   Reply With Quote
gray tank, gray tank odors, gray tank smell
Do we really need a gray water tank? live2dive Waste Systems, Tanks & Totes 10 05-11-2007 09:52 AM
Controlling Black Tank odor thecatsandi Waste Systems, Tanks & Totes 32 09-14-2006 06:18 PM
Gray Tank milesmason Waste Systems, Tanks & Totes 4 07-21-2005 07:50 AM
stainless gray tank wol Waste Systems, Tanks & Totes 1 10-10-2004 11:31 AM
Gray tank repair cadonnelly Waste Systems, Tanks & Totes 3 07-18-2003 12:52 PM
