Old 05-01-2014, 09:58 PM   #1
2004 19' International CCD
Ventura , California
What brand to order for leaky waste valve
Hi:
Our 2005 19' Bambi CCD has a leaky waste valve. I found a "twist-on-valve' by Valterra on Camping World. Does anyone know if this is the correct valve that would work on our Airstream? We are going to replace ourselves .
Thank you,
Laurie
DoggerStream is offline   Reply With Quote
Old 05-02-2014, 03:17 AM   #2
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
I do not know about your Airstream but ours does not use a twist on valve like the one you speak of but rather is a bolt on flange type. Maybe a call to an Airstream dealer would be wise? They will be able to supply you with the exact valve you need without any guesswork.
Good luck!
Bruce
Bruce B is offline   Reply With Quote
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 20 04-12-2017 01:31 PM
leaky leaky leaky Zellia All Argosy Trailers 8 08-07-2015 05:25 AM
leaky gaskets in waste discharge jaiman Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 09-01-2003 04:11 PM
