Old 10-29-2010, 07:30 AM   #1
1966 20' Globetrotter
Killingworth , Connecticut
What black valve for a 66 GT
So i'm to the point of needing to buy the entire valve assembly for a 66 GT. when I got it the valve was ripped out of the tank. replacing the tank with an ABS above floor similar to original. so the penetration will go from the floor, through the belly pan and then dump I'm assuming either straight down or curve 90 degrees and come out the street side.
So here are the questions:
1. Valterra, Thetford or other type?
2. What parts do I need as I'll be plastic welding this to an ABS tank?
3. Straight down or side/rear discharge?
thanks, Rob in CT
860-663-2004 home office
CtRobert is offline   Reply With Quote
Is there a black-water-tank valve? hagnik Waste Systems, Tanks & Totes 1 08-31-2009 07:18 AM
Black Tank valve redo GlenCoombe Waste Systems, Tanks & Totes 3 09-15-2006 07:05 PM
black tank leak above valve gary Waste Systems, Tanks & Totes 2 06-03-2004 08:42 AM
Sticky Black Water Valve squeeky Waste Systems, Tanks & Totes 3 04-09-2004 10:47 AM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 08:22 PM
