Old 03-29-2016, 10:45 PM   #1
2018 19' Flying Cloud
Eugene , Oregon
What are these valves and why is one dripping.
When filling my testing my hot water and running the cold water, I noticed water dripping from this valves to what I think is the grey water holding tank. About 45 minutes later the water drips were gone and is now dry. Any idea what those calves are and why it would drip/leak and then stop?
Name:	ImageUploadedByAirstream Forums1459313105.525082.jpg
tjwoods1 is offline   Reply With Quote
Old 03-29-2016, 10:46 PM   #2
Eugene , Oregon
Sorry about the typos... Darn auto-correct.
Old 03-30-2016, 04:30 AM   #3
1999 30' Excella 1000
small town , Maryland
They look like nice fresh water drain valves. Ball valves shouldn't leak. My '99 has 2 petcock valves for drains... just like car radiators.
streaminwild is offline   Reply With Quote
Old 03-30-2016, 04:36 AM   #4
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
They may well be your water pipe system low point drain vaves - one for hot, one for cold.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 03-30-2016, 05:56 AM   #5
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
I have a 2015,16 ft and have determined they are a low point drain. But not exactly sure what they are draining. The freshwater drain is located upfront on the roadside. I don't recall them being identified in the owners manual. Perhaps someone can clear this up for us.
Ron
Ron
Ron A is offline   Reply With Quote
Old 03-30-2016, 06:33 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
They are the low point drains for the plumbing, for winterizing.. The other drain Ron A mentions is for the fresh water tank.
2012 Dodge Durango Hemi/AWD
Old 03-30-2016, 06:51 AM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Was it leaking from the stem? If yes, then the packing around the stem inside the valve probably dried out and shrank, and once water pressure was applied, it swelled up again and re-established the seal. Might be an o-ring instead of packing, but same net result. Keep an eye on it. If you notice it dripping again, time to take it apart and replace the stem seal. Or just replace the valve.
Chris
Old 03-30-2016, 10:29 AM   #8
1998 30' Excella 1000
Livingston , Texas
Also note that those valves are subject to freeze damage if not winterized/drained.
Siegmann is offline   Reply With Quote
Old 03-30-2016, 10:33 AM   #9
jackson center , Ohio
Low point drains.Last year after winterizing I closed them and must of had a little water left in the line. Froze and split brass on valve
Schu is offline   Reply With Quote
Old 03-30-2016, 10:45 AM   #10
Minipad's Avatar
2013 23' FB International
2013 25' Flying Cloud
In the Rockies, 6700' , Colorado
Those are your low point drain valves. The one on the left in the picture is likely your hot water and the other is the cold. If they drip from the opening, open and close the valve a few times and then leave it closed. Often, there is road grit, etc. that gets in the valve and may prevent a seal. When you winterize, leave them open. If the valve is left open, it is very unlikely that it will freeze. The PEX pipes that feed those valves run vertically from the 90 fitting on the near side of the valve in your picture. So the only moisture that can stay there is just in the part of the valve that you see. With the valve open, there is too little water for the expansion to split the valve.
Minipad is offline   Reply With Quote
Old 03-30-2016, 02:23 PM   #11
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Brian.
Hey Brian;
where the heck did you get 'Centramatics' in Canada?
MelGoddard is offline   Reply With Quote
Old 03-30-2016, 03:55 PM   #12
Minno's Avatar
1972 31' Sovereign
I forgot the real reason why it drips. Cuz it can't go 'sniff'.
Old 03-30-2016, 05:01 PM   #13
ToyHouse
2014 27' FB Classic
Quesnel , British Columbia
Bit off topic but Mel asked about Centramatics in Canada. You can phone Centramatics in Texas , they'll put you in touch with Pat Dolla in Quebec,
por15canada@gmail.com. Similar pricing give or take Cdn to US exchange and no customs/duty hassles.
ThomasHoward is offline   Reply With Quote
Old 03-30-2016, 05:04 PM   #14
Wingeezer's Avatar
2005 30' Classic
Originally Posted by MelGoddard View Post
Hey Brian;
Hello Mel,
I ordered them from "Inland Andy" in California. At the time I bought them I don't think they were available in Canada.
Brian. (Presently in Asheville NC on our way home from Florida! Put all new brake assemblies on our trailer when in Florida - much better brakes now! Should have done it sooner! Fixing up the ground connections surely helped too!)
2005 Classic 30'
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 06:07 AM
Why Does My A/S say one thing on one side and something else on the other Angel73 Title, VIN & Registration 3 05-12-2006 09:46 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
