Old 05-24-2006, 01:05 AM   #1
RoadRunner
1972 27' Overlander
Hattiesburg , Mississippi
Question Weep/drain holes in tank pan?
I had a new tank pan fabricated because the old one was rusted out through the bottom. I assumed this was caused by water (from whatever leak) standing in the bottom of the pan for years. The styro was stained as if sitting in water a long time. Should I make a drain hole in the pan with maybe a pipe or tube that goes through the belly skin to keep this from happening again? I have no idea if the original pan had any such thing, it was so far gone. I am having to replace the angle iron and frame extenders that held the pan in place. They were rusted, too. How far should I dig to discover more rust? as far as I can see looking forward under the skin, all looks well but I'm not sure about the outer edges (outriggers?) are these commonly rusted out?
Regards,
Roy
rcloeffler is offline   Reply With Quote
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
