Old 03-16-2007, 01:16 PM   #1
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Water tank repair
Can anyone tell me a good "glue" to repair a plactic water tank. There is a crack close to the filler connection that I want to repair.
tn2... Bad thing about doing nothing is you never know when you're done.
tn2 is offline   Reply With Quote
Old 03-16-2007, 01:43 PM   #2
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
birmingham , Alabama
Images: 26
can you tell what type of plastic it is? it could be ABS, polyethaline(sp?), or even fibreglass...
if it's ABS, it can be 'melted' or solvent welded using MEK. locate some scrap ABS and place some chips of the scrap along with some MEK in a glass jar for several hours or days and it will form a 'glue' that you can use like pvc cement.
if you can't tell what it is... test an area with different type solvents (MEK, acetone, lacquer thinner, etc) to see what disolves it.
if nothing dose, you can always 'weld' it with and old soldering pen or something similar by melting the cracked area back together.
Doug
59er is offline   Reply With Quote
Old 03-16-2007, 03:36 PM   #3
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Talking tn2
If you are going to go to all the trouble of taking it out and welding not knowing if it will hold ,replace it with a new tank.Save yourself a lot of work. Regards from Russell in sunny Tucson Az.
RUSSELL is offline   Reply With Quote
Old 03-16-2007, 04:27 PM   #4
Repairing the old water tanks is usually a waste of time. The plastic has become brittle, and that cannot be repaired.
Melting the crack back together, just causes more brittle spots.
Trying to fix it with solvent, is also a waste of time.
Old 03-16-2007, 04:44 PM   #5
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Level of effort
...Trying to fix it with solvent, is also a waste of time.
Unless you are willing to treat the ENTIRE tank with solvent & filler instead of just the cracked area.
OTOH, fresh-water tanks are usually made of the type of plastic that can only be repaired by welding. If that is your case, I would recommend having a new tank built if a "drop-in" replacement can not be found.
Tom
Old 03-16-2007, 04:52 PM   #6
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I had the local RV dealer weld mine and it seems fine. I guess time will tell....
www.nesa.org
Air No. 6427
Old 03-16-2007, 05:11 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
tn2,
Just how old is your A/S? I have done plastic welding on a number of cracked tanks and 'most' have held up very well. You will know right away if the weld didn't take.
If you are unfamiliar with plastic welding, find a body shop or RV repair shop and have it professionally done. If the integrity of you tank is otherwise in tack and isn't brittle from age, welding will probably do the trick. The key to proper welding is to use the exact same material as the tank, which is most likely polyethelyne.
Old 03-16-2007, 05:54 PM   #8
TomW's Avatar
1967 26' Overlander
One more repair place
Originally Posted by lewster
... If you are unfamiliar with plastic welding, find a body shop or RV repair shop and have it professionally done. ...
Automotive radiator repair shops are encountering a lot of radiators with pastic endcaps. They also have the right tools.
Tom
Old 03-16-2007, 06:44 PM   #9
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Hey ....Thanks for all the good imformation. Since my crack is up toward the top of the tank....only time it leaks is when full....of course I want no leak at all....but I feel it's worth a try to fix it.
Charles
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
what holds black water tank in place tw64 1959-69 Tradewind 3 06-16-2004 11:05 PM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 09:02 AM
Regarding original water tank clean out - thank you! 60stradewind Fresh Water Systems 0 08-22-2002 12:00 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
