Old 09-17-2006, 03:17 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Water tank plate underneath
My tank is empty the steel plate with a bolt in the middle of it is badly rusted.
Can I safely remove the bolt to get the plate repainted, or will something fall on my head?
Is it easy to put back in?
'77 Sovereign Intl 31' CB
Old 09-19-2006, 08:53 AM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
BUMP
Anyone, help out on this issue?
Old 09-19-2006, 09:13 AM   #3
1976 25' Caravanner
Campton , New Hampshire
Mine is a '76 and should be the same . The only thing that will come off is the plate and the bolt that holds it . If it hasn't been off for a while I would use some penetrating oil on it . This is also the place where I installed a drain valve to empty the tank . When the plate is off you will see a rubber hose . This hose goes from the tank to the water pump . Cut the hose and splice in a drain cock . Good luck
ticki2 is offline   Reply With Quote
Old 09-19-2006, 09:52 AM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
thanks much that was a big help
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 07:58 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 11:35 AM
White water tank drain ramoore53 Fresh Water Systems 4 05-01-2002 11:08 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 12:54 PM
