Old 05-19-2004, 05:20 PM   #1
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
Water flow question...
On trailers/motorhomes with gray water tanks, is there a feature available that when you are hooked up to a sewer outlet, that you can allow your gray water to flow straight out to the sewer rather than to your gray tank first?
I can't remember exactly, but I believe my old SOB used the gray tank, then you had to open the valve to let it all flow out to the sewer.
The reason I am asking, is because I am retrofitting my trailer with gray tank plumbing, and am putting in a valve/diverter to either direct the water to the tank or directly out to the sewer. Obviously if I am at full hook ups, I wouldn't want to be filling my gray tank. For rinsing out after blackwater dumps I would just need to turn on a faucet for a minute or two.
Thoughts? Opinions? Flames?
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 05-19-2004, 06:20 PM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I think what you do is just leave the grey water dump valve open. (leave the black one closed). water goes into the tank, and then immediately exits and goes down the chute. no need to run a separate line. the black and grey lines join DOWNstream of their respective valves, so each can be operated seperately.
I think its also common advice to let the grey tank fill on the last day of your stay, so you have a ready supply of soapy water with which to rinse out the stinky-slinky.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Outside water hookup question. 68 Suburban Fresh Water Systems 6 10-05-2013 02:25 PM
Water question Tin Hut Fresh Water Systems 5 01-04-2004 07:52 PM
Water pump question ipso_facto Water Heaters, Filters & Pumps 12 12-04-2003 12:12 PM
No water flow Michael W Plumbing - Systems & Fixtures 4 10-12-2003 08:26 PM
City Water Valve Assmbly Question sladew Fresh Water Systems 3 08-11-2003 10:38 PM
