Old 01-31-2004, 11:03 AM   #1
water drain valve leaking - help!
My fresh water drain valve is leaking both on the inside and outside. There is just a very small leak inside and I keep a small towel under it to absorb the water. There is also a leak underneath the trailer from the drain line. I can sometimes work with the valve handle and stop the leak underneath the trailer. I would like to replace the valve but the water tubing is crimped to the valve. Does anyone have any suggestions on how to replace the valve with fittings that are not crimped on? Thanks.
Wayne
wayner1239 is offline   Reply With Quote
