Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 10-03-2010, 12:55 PM   #1
1965 26' Overlander
El Prado , New Mexico
water backing up into shower pan????
Hello,
Can anyone help me with the problem I am having with waste water from my sink backing up into my shower pan.? If I wash a load of dishes and then let the sink stopper go, the water backs into my shower pan.
I do have the sink and shower plumbed so that I can either dump into the black tank, or by-pass into a hose that eliminates grey water.
Help, this is really not an ideal situation.
Thanks Kewpie
kewpie is offline   Reply With Quote
Old 10-03-2010, 01:00 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Assuming the tank is not full and this only happens during the sink draining and then drains down in the shower the flow rate is too high for the hose you are using.
I would try and make a stopper for the sink that slows the drainage rate. The shower is the lowest point and will show any backup first.
2004 Excursion 4x4
Old 10-03-2010, 03:04 PM   #3
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I'd suspect that something is wrong with how the plumbing was changed from the "standard" of sink-goes-to-gray-water. Has it worked in the past?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Custom Shower Pan Tom Bray Sinks, Showers & Toilets 20 04-30-2017 09:29 PM
Anyone curious about what's under the shower pan? SafeHarbor 1978- 1979 Excella 500 7 12-13-2010 03:22 PM
nu2airstream. Shower pan full of water A Beck Sinks, Showers & Toilets 3 07-14-2010 12:15 PM
Shower pan removal? glacierrunne Sinks, Showers & Toilets 2 07-02-2006 09:45 PM
64 Bambi II shower pan Pat McSween Sinks, Showers & Toilets 2 08-02-2003 02:53 PM
