Old 06-08-2009, 02:56 PM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Wasting my time?
Please take a look at the photo. Is there a way I can put a new valve on this black tank? The white flange appears to be glued and threaded to the black flange which looks to be fiber-glassed to the fiberglass tank. Any good ideas out there or should I be looking for a new tank? The one I have sat above the floor and was a 16 gal.
SilverHoot is offline   Reply With Quote
Old 06-08-2009, 03:13 PM   #2
You must cut the original brass outlet off the fiberglass tank.
Then, you can carefully fiberglass the flange, the white part you show in your photo, to the tank.
Make sure that you orient the flange so that the valve can easily be installed.
Other than that, there is no simple solution, since your Airstream is from the early 60's.
Old 06-08-2009, 04:18 PM   #3
SilverHoot's Avatar
1967 24' Tradewind
Brass outlet?
Mine does not appear to have any brass. The black part that is fiber-glassed to the tank is a black, I would guess ABS material. I checked from the other side of the tank where the threaded (also an ABS type of material) toilet flange area is and don't see any brass from the inside of the tank either. I've attached a photo of the white flange and you can see all the screw holes are in poor shape. I've not worked with ABS but was wondering if it is feasible to somehow fill and redrill the holes so that I could attach a new valve.
Old 06-08-2009, 05:29 PM   #4
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Cut it out and do what Andy recommended. That flange is not worth salvaging if you patch it up and reinstall the tank you will be very unhappy when you are dropping the tank to replace the patched flange.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 06-08-2009, 07:59 PM   #5
1994 30' Excella
Mississauga , Ontario
I guess you could try cutting the white flange off the black flange with a grinder. If successful you could glue a new white one on. Then you wouldn't have to do any fiberglassing. If it doesn't work then you could cut the black one off and start from scratch.
Alternatively, have you checked on the price of a replacement tank?
Al
Old 06-09-2009, 07:13 AM   #6
SilverHoot's Avatar
1967 24' Tradewind
Jim, unless I were sure as to the integrity of the repair, I would not reinstall the tank. Never worked with fiberglass is another problem.
BigAl, I can't seem to find a tank of about the same size, 16 gal. I'll continue to look.
Old 06-09-2009, 08:00 AM   #7
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
All-Rite.com will make a tank to your exact specifications with the inlet and outlet holes in the size and thread pattern of your choosing and put them exactly where you want them. I had them make me a fresh water tank and it was within 1/16" of my measurements.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
New time streamer, long time dreamer Wilburstream Member Introductions 25 01-12-2009 08:32 PM
A time to buy, a time to sell jeffyockey@m Member Introductions 2 03-12-2008 10:39 PM
First time CANADIAN BOB Member Introductions 9 06-19-2007 01:51 PM
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 08:55 PM
Part Time vs Full Time (Days/Year) InsideOut Community Polls 30 10-23-2005 09:43 AM
