Old 08-05-2012, 09:10 AM   #1
1997 25' Safari
glen allen , Virginia
Waste Water Adapter - mine broke off
Does anyone know where I can get the adapter...M&M Hose Co. #05 2285 thanks
tslaven is offline   Reply With Quote
Old 08-05-2012, 09:28 AM   #2
pbearsailor's Avatar
Port Hadlock , Washington
Vintage Trailer Supply is always good.
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 08-05-2012, 09:30 AM   #3
Ottawa , ON
Are you talking about the Valterra to Thetford adapter? (adapts the hose for the different pin styles those two companies use)
If so, then most RV dealers that I have seen carry them...
Old 08-05-2012, 10:35 AM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings tslaven!
Welcome to the Forums and the world of Airstreams!
A little additional information is needed to give an accurate answer to your question. If you are referring to your holding tank dump valve adapter that mounts the dump valve to the tank, you may find multiple issues. On many of the Vintage Airstreams where the dump valve assembly is centered below the rear bumper, a broken dump valve mount can be a greater issue than jus the valve and mount . . . if the break is related to having the assembly drag on the pavement while entering/exiting a steep driveway, you may find that the tank is fractured as well requiring a major repair to the tank or total replacement. When this happened on my '64 Overlander, the damage was so extensive that a new tank and valave assembly were required. Additional descriptive information along with a photo would help in getting suggestions.
Good luck with your research and investigation!
Kevin
Kevin D. Allen
AIR #827
Old 08-05-2012, 11:29 AM   #5
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
I googled it and came up with an old forum thread
http://www.airforums.com/forums/f444...ctor-7182.html
sure sounds like the thetford to valterra adapter available at most rv stores.
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
