Old 09-30-2006, 08:46 PM   #1
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Waste valve handle
Where can I find a handle for the original waste valve on my 63 GT?
Cochese is offline   Reply With Quote
Old 09-30-2006, 09:04 PM   #2
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
What does your waste valve look like? Does it look like this? If so, mine is just a small sturdy strip of metal drilled with a hole to fit over the vavle pin. The metal strip is attached to a T-handle. You insert it through the hole in the rear bumper, fit the handle hole over the valve pin, turn counterclockwise, and pull. I can't get a picture of mine until next week sometime, but it looks like something that could be easily made. I was using a channel lock directly on the valve pull until I found the handle in a box under one of the twins.
Name:	Black Valve.jpg
Traveling With Elvis
life with a 1956 Sovereign of the Road
Aluminocentricity
Sugarfoot is offline   Reply With Quote
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 1 05-21-2010 05:55 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Tedford dump valve 77caravaner Waste Systems, Tanks & Totes 0 09-29-2002 04:58 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
