Old 06-24-2016, 08:08 AM   #1
Waste valve
I am rebuilding valve that comes off the tank on side . This is a 1970 airstream sovereign 30'. Bought the thetford valve ring, etc but missing one piece that looks like a sanitary t but on end there is a plate for 4 screws and on other side of that a fitting with some nubs that one of the other pieces twists onto. I cannot find this strang sanitary t anywhere. Any help? Also where do I get more foam to put around waste tank. Can I replace my fresh water tank from underneath the trailer or do I have to remove the floor?
paulmichie is offline   Reply With Quote
Old 06-27-2016, 12:27 PM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
It's easier to order a new valve. The fresh water tank should be under the couch or bed up front. It sits above the subfloor, unless your trailer had been modified
Matt
rugjenkins is offline   Reply With Quote
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 20 04-12-2017 01:31 PM
West Boondocking Waste Water and Food Waste Disposal Ray Eklund Boondocking 2 10-18-2015 02:38 PM
Waste (Black Water) Waste Management Snaken49 Waste Systems, Tanks & Totes 4 07-08-2011 10:37 AM
