waste tank pan question?
Hello,
I have yet another question. Did the 1966 Safari have a metal waste pan holding up the black tank? When I took out the black tank it was attached to the floor with screws and the Styrofoam 'pad' was resting on the belly pan. I know that area had been worked on based on the number of fiberglass and putty patched I found. What I'm wondering is if they had put it back together the same way or 'rigged' it to work? If there was a metal box how was it attached, if not, what is the best way to attach the new black tank? The new one is ABS not fiberglass and slightly larger.
Deborah
