I'm parked in a spot where the ground sewer pipe is too high. The owner has installed a lower t-pipe for me to hook up my septic. Is this going to work? I thought my sewer lines should empty straight down, not sideways into the pipe. I can just see it blowing off. hmmm Duct tape?? I was going to sit here a couple of months and sure want to be set up securely. Any ideas?
It may not be optimum but it should be OK - if I have what you describe pictured right.
Duct tape is OK for a short time but sun rots it pretty quick. I'd probably back the tape up with a strap of some sort.
Dave
__________________ AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Even if you are hooked to a sewer line you need to keep your valves closed (especially the black tank) and only dump when the tank is near full. If you leave the black tank valve open the solids will not be washed out of the tank leaving a condition in the tank called the "Black Hills"
jason, that might work but i've never had black hills with 5 gallons or room left in the tank!
most solutions end up being messy. they are a few tricks to try such as the hot water. you can try filling the slinky with water with the sewer end elevated to try to put pressure into the tank to push the hills back. you will probably end up wearing some of the output if the tank clears.
you can buy a cap with a hose fitting on it to blow some water back into the black tank. you just have to be very careful not to blow up the tank or creating a black hills fountain in the trailer. those situations are undesirable.
Ricky give life. kidney & pancreas transplant 9/9/06
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Ricky, How small is your black tank? I can get about 15 gals in mine. That must be some really big black hills if you can't fit any water in the tank!!!!!!!!!! wooooooow
Jason
I always start with water and blue solution, but it wasn't emptying very well. So, those hills were forming.
We were able to get a garden hose through the back hatch, and through the cupboard under the bathroom sink and spray the hills. Actually my son did that. It cleaned out quite nicely. If that's possible. If anything with black hills can be nice.
An ounce of prevention... as they say, but sometimes there's problems. Especially when you're parked long-term. First, you don't get the rocking of the tank when you're traveling and then, sometimes, that tank valve doesn't get completely shut...
