Old 09-05-2014, 01:21 PM   #1
Savage68's Avatar
1974 Argosy 22
Hamilton , Montana
Waste gates leak- Valterra or thetford?
One of the surprises we had was that the black tank leaks liquid past the gate.
Someone, possibly PO cut away some of the underbelly skin to expose the access for replacing the two gates. I was hoping that meant they were already replaced, but no joy, I get to do it next spring.
So research shows there are two brands, and since LaTortuga was born in '74, which ones will I need?
Savage68 is offline   Reply With Quote
Old 09-05-2014, 01:49 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Savage,
White = Thetford, black = Valterra. If not modified by a prior owner it should be Thetford.
Bill
Just my personal opinion
Old 09-05-2014, 02:25 PM   #3
1974 Argosy 20
Kooskia , Idaho
Yes, if it is white, it is Thetford. Some have said that they think that the Valterra are superior in some ways, but I can't recall why. The Valterra equipment is much cheaper and everyone carries it. The Thetford is harder to find and much more expensive. Rangtash Brothers in Missoula has and can get for you most any Thetford parts you want. Other dealers look blank when you ask for Thetford things.
If you are replacing you might consider converting to Valterra if it is not a huge additional job. That advice is based on availability and cost considerations only. My long experience with Thetford has been positive as far as how it works.
Old 09-05-2014, 05:25 PM   #4
Bex
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
Before you replace, work a few tanks of water and mild detergent through and open/close the gate rigorously as it emptying. This fixed mine.
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Old 09-06-2014, 01:37 PM   #5
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
You can also rebuild Thetford (and Valterra). It is a matter of replacing the rubber seals that the blade slides through. This is much easier than replacing the valves with the attendant pipes and plumbing to be done. Check with Inland or other AS parts folks for rebuild parts.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 09-06-2014, 07:45 PM   #6
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
I was told by a Thetford tech last year that they are starting to phase out the gate valves.
DryFly is offline   Reply With Quote
Old 09-06-2014, 09:24 PM   #7
Air Apparent's Avatar
Northern Illinois , Illinois
Our 2005 Classic 30 came with a Thetford. Our 2008 Classic 34 came with a Valterra. Both were purchased new from a dealer.
Dave
2008 Classic 34
Dodge Ram 2500 Quad Cab CTD
AIR #7317 WBCCI #1772 TAC-IL 1
Air Apparent is offline   Reply With Quote
Old 09-07-2014, 06:40 PM   #8
Bex
There is also this, which I never new existed but found on another site whilst looking for something else (as you do)
Twist-on Valve - Valterra T58 - Sewer Fittings & Adapters - Camping World
Old 09-08-2014, 07:57 AM   #9
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
We thought about one of those, but it's a bit more complex because you have to get a Thetford to Valterra adapter in order to fit it on. For some models -- ours included -- space is limited, making the solution unworkable.
Lynn
WBCCI 21043
Old 09-26-2014, 08:00 AM   #10
1976 Argosy 28
Lynchburg , Virginia
I thought my valve was leaking too. I pulled it out and rebuilt it. It still leaked. Further inspection showed the leak was actually a crack beside the tank hole. Not the valve but beside it in the actual tank. Project was put on hold when we figured this out, about 2 months ago. I plan to try to plastic weld it to fix the problem. Or buy a new tank.
bacnmc is offline   Reply With Quote
Old 09-26-2014, 08:26 AM   #11
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My Thetford valve on the gray water tank was leaking on my 86 Limited. It also had the special Thetford bayonet connector that required special slinky hoses and caps. I found the Thetford sealing design was more complex than the Valterra.
I switched to Valterra valves and have been satisfied these last two years. No leaks, and I can use standard 3" slinky hoses and caps. It was a significant amount of work to drop the big tank cover pan. Airstream designed it this way to keep the tanks from freezing when used in cold weather, but it isn't the greatest for maintenance. The new Valterra valves are on top in the photo.
David
Name:	1205 New Valtera Plumbing.jpg
Old 09-27-2014, 05:45 AM   #12
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I do believe that the new trailers are all coming with Thetford.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 11-03-2014, 05:28 PM   #13
danjoe91's Avatar
1985 32' Excella
Valley Village , California
Images: 16
waste valve access
I have an '85 Excella. My grey water tank valve is leaking, so I want to replace both valves. Do I have to unbolt the entire waste tank shield, or cut out an opening big enough to replace the valves? If so, what tool cuts this best?
Name:	tank valves.jpg
danjoe91 is offline   Reply With Quote
Old 05-30-2016, 08:10 AM   #14
Panacea , Florida
thetford valve issues
Okay, I have tried to do some research here and so far it looks as though my '91 Excella 1000 has the Thetford design. So my problem is that the black water tank valve seems to be stuck slightly open so when I go to empty the tank I have to be very quick to connect hose or it drains that nasty stuff before I open the valve. Not a lot mind you but enough to be embarrassed and concerned.
Seems to me that there is a way to adjust the valve stem so it will not leak. I understand from other comments that perhaps the valve is partially stuck open and that pushing and pulling the valve while dumping might free it up.Not ready for the conversion or full on repair yet but will do it if all else fails. Problem we are on the road for the next 2-3 months and finding a place for this supposedly messy job is problematic.
Standing by for tips/advice.
Silver Burrito is offline   Reply With Quote
Holding Tanks Drain - Thetford to Valterra Rebuild dbj216 Waste Systems, Tanks & Totes 5 06-08-2012 03:34 AM
Opinions welcomed.. Valterra or Thetford Phrunes Waste Systems, Tanks & Totes 13 08-20-2011 07:40 PM
Valterra to Thetford connection Craig Waste Systems, Tanks & Totes 30 03-05-2011 07:49 PM
Replace a Thetford Valve with a Valterra? thunder433 Waste Systems, Tanks & Totes 2 03-03-2008 04:41 PM
Thetford vs Valterra pilgrim_still Waste Systems, Tanks & Totes 8 06-11-2005 01:34 PM
