Old 10-27-2010, 09:39 AM   #1
1973 31' Sovereign
Fort Worth , Texas
Images: 27
waste gate cap install
1973soverign rear bath.
I have seen a waste cap with a gate on it. Not sure where to buy it or what size. The waste cap I have is slightly larger than the hose fitting that came with the trailer. I have to shove the wrong end into the whole on my trailer to use it.
My black tank valve doesn't close all the way ( planning on getting in there soon and seeing if there is toilet paper stuck etc)
How hard is it to replace the waste cap with one that has a gate on it?
By the way the yellow stuff you see on the sides of the cap is something called "Plastic weld" that I get from Oreilly Auto Parts. (NOT plastic Epoxy) It is AWESOME for fixing anything plastic. I had dropped the cap and busted one of the clips. Fixed with plastic weld it is now much stronger than originally.
We will soon begin traveling with our family of 5 (and a large dog) Looking forward to remodeling our Airstream, awesome adventures, and meeting new people.
www.steventothemax.com
steven2themax is offline   Reply With Quote
Old 10-27-2010, 09:46 AM   #2
1973 31' Sovereign
Fort Worth , Texas
Images: 27
Are theteford and valterra the 2 different sizes? can I get something like this which will just twist on?
RV Camper Twist on Waste Valve, 3": eBay Motors (item 190326894150 end time Oct-30-10 13:23:42 PDT)
Old 10-27-2010, 10:04 AM   #3
1973 31' Excella 500
Spring Green , Wisconsin
Yes, Thetford and Valterra are different sizes. I had to pick up a Valterra universal adaptor on ebay so I could use a standard RV drain hose for my black tank.
VALTERRA Universal Adapter Converts Thetford Valve: eBay Motors (item 140337156368 end time Nov-24-10 11:58:42 PST)
With the adaptor you should be able to use the valve that you've linked above.
The best solution would still be to repair the tank valve, IMHO.
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Old 10-27-2010, 02:43 PM   #4
1973 31' Sovereign
Fort Worth , Texas
Images: 27
Thanks Lew. exactly what I needed.
I also plan to repair the tank valve.
Waste Vent Cap dieseleagle Roof Vents, Skylights & Fans 44 11-24-2014 08:29 AM
Need waste cap with hose fitting TX Sister Waste Systems, Tanks & Totes 27 01-31-2011 07:07 AM
New Waste Gate Valve for Black Tank? TylerFyre Waste Systems, Tanks & Totes 5 06-10-2008 01:18 PM
Waste Water pipe cap - 1964? RetroTrailer 1960 - 1964 Globetrotter 2 02-21-2008 12:06 AM
Waste pipe cap flitzwhopper LP Gas, Piping, Tanks & Regulators 2 11-04-2006 06:01 PM
