Old 02-04-2015, 06:59 AM   #1
1982 27' Excella
Huntsville , Texas
Waste Dump Valve
I recently purchase a 1982 excella rear bath. The dump pipe is by the rear bumper but does not have a valve just set up for quick disconnect to a flex pipe. Is there a valve somewhere that I did not see or has the system be modified by a previous owner?
GMarugg is offline   Reply With Quote
Old 02-04-2015, 08:29 AM   #2
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
If your '82 is anything like our '69 you'll find the "T" handle in the rear compartment.
Here's a few pic's ,
1st is looking through the rear access door the "T" handle is to the left of the 'faucet' knob and behind the pressure regulator hidden from view. It most likely has 2 wire bails slipped over the "T" handle, just move them sideways to lift the "T" handle to dump.
Pic 2 & 3 This is after I gutted the interior and you can see the "T" handle better.
Pic 4 is what that area looks like today, But that's another story.
ID:	231696   Click image for larger version
ID:	231698   Click image for larger version
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 02-19-2015, 03:59 PM   #3
1982 27' Excella
Huntsville , Texas
Dropping pan Under rear
If I have to drop the rear pan under the valves, gray and black water tanks will the empty tanks support themselves?
Old 02-19-2015, 05:36 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The aluminum belly pan should not be support the tanks. The tanks should be supported by framing members.
Old 02-20-2015, 07:27 AM   #5
1982 27' Excella
Huntsville , Texas
Thanks, I appreciate the help.
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 20 04-12-2017 01:31 PM
Waste (Black Water) Waste Management Snaken49 Waste Systems, Tanks & Totes 4 07-08-2011 10:37 AM
Waste dump hose storage location bkahler Classic Motorhomes 7 09-28-2007 06:38 PM
