Old 01-25-2016, 06:44 PM   #1
2001 30' Classic S/O
westcliffe , Colorado
waste Connectors
2001 30' classic that requires a special type connector to drain away waste. It is slightly larger than the today's standard connector. Any feedback on where to get this would be appreciated
jyourish is offline   Reply With Quote
Old 01-25-2016, 07:21 PM   #2
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Not sure if the 2001 is the same size as my 1978 but I found an adapter at camping world.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 01-25-2016, 07:29 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
You probably have a Thetford connector. That would have been one of the last years they used them, I would think. There are 3 things you can do:
1) You can get an adapter to couple the valve to a now-standard Valterra fitting.
2) You can make a hose with a Thetford end on it so that no adapter is necessary
3) You can update the plumbing on your trailer, replacing sufficient components to end up with a Valterra fitting.
The pros and cons of each are pretty clear. vintagetrailersupply.com has parts for all alternatives as do most Airstream dealers and better RV service shops that work on older rigs.
Camping World and similar places may have the adapter (look for a "Thetford adapter") but typically will not have hose ends.
Fleixble gas connectors on Suburban furance? Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-20-2009 07:36 AM
Pex connectors and bad temper crispyboy Fresh Water Systems 36 05-06-2008 08:31 PM
P30 fuse blocks and connectors bkahler Mechanics Corner - Engines, Transmission & More... 6 06-08-2007 07:10 AM
240 volt connectors??? gparker Electrical - Systems, Generators, Batteries & Solar 4 07-31-2006 04:57 PM
12vDC wall connectors walter1 Electrical - Systems, Generators, Batteries & Solar 10 09-19-2004 12:53 PM
