Old 04-03-2014, 06:05 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
"Wanted"-vent pipe cover for Bambi II
I think I am going to need another of these vent "covers" for my 1964 Bambi II rebuild. I am relocating a plumbing vent tube and wish to keep everything looking original.
Anyone out there have a spare? Here are some pics of what I am hoping to find. Obviously, the pipe would come out through this...
ID:	208914   Click image for larger version
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 04-03-2014, 07:12 PM   #2
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
I think you really need one of these or something similar. I'm pretty sure you have parts missing. Out of Doors Mart and Inland RV also carry these
Metal Roof Pipe Cover
DryFly is offline   Reply With Quote
Old 04-03-2014, 07:33 PM   #3
1964 17' Bambi II
I will go to this if need be. The only part missing is the pipe that went through the casting. I sealed under both of mine while renovating to keep water out. All plumbing is gone, gone, gone!
The pipe was open to the elements...not a great design, but that is the way it was designed. Thanks for the tip, though.
Ben
Old 04-04-2014, 05:22 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If you're relocating a plumbing vent, then move the cover you've got, and rivet a (properly caulked) circular aluminum patch over the former hole.
Not a bad design, either. The amount of precipitation that would go down the vent stack is trivial unless you live in the Olympic peninsula or south Louisiana, and that rainfall would only end up in your holding tanks anyway. Your home vent stacks are open to the elements as well. There is no harm in leaving your new vent stack open the way the old one was.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Dumb sewer vent pipe cover gasket Questions Scooter241 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 11-21-2012 04:23 AM
Sewer vent pipe cover gaskets Inland RV Center, In Leaks - Weatherstrips, Gaskets, Caulks & Sealants 43 06-10-2009 09:04 PM
Replace original vent pipe cover? rluhr Roof Vents, Skylights & Fans 18 08-30-2004 12:12 PM
