Old 09-05-2011, 08:01 AM   #1
tr0y's Avatar
Las Vegas , Nevada
Venting DWV
I am in the early stages of planning my 2nd ground up remodel / build and was wondering about venting the plumbing.
Do you vent as you would residential plumbing for good flow into the tanks ? Or is there some specific way to vent RV plumbing ?
T
tr0y is offline   Reply With Quote
Old 09-05-2011, 08:05 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Both holding tanks will need to have a vent. They can have a common outlet in the roof, or be separate. If you have a center bath unit, a single roof vent would be enough for everything. If you have a rear bath unit, you should consider a vent for the galley sink drain, as well. That vent should be separate, only because it would be tough to run a vent pipe throughout the trailer just to make a single roof vent.
Old 09-05-2011, 08:38 AM   #3
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
In a Word, "Yes"...
The plumbing principles are the same as they relate to vents in houses and RVs. Manufactures are guided (and regulated) by different building codes than residential contractors to be sure, but the principles of plumbing and electricity remain the same.
The plumbing schematics are widely available for every Airstream, and the same general principle applies in them all.
The drain lines to each holding tank are vented to ensure good flow from the sink,shower, or toilet to the tank by eliminating any vacuum in the lines.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Shell off transmogrification truckasaurus Repairing/Replacing Floor &/or Frame 498 02-04-2012 06:19 PM
Refrigerator venting toastie Refrigerators 6 06-27-2011 04:40 PM
Wall oven need venting?? adamgraves Stoves, Ovens & Microwaves 0 04-28-2011 10:00 PM
3 refrigerator installation questions Lothlorian Refrigerators 16 03-06-2011 09:40 AM
