Old 03-30-2014, 09:51 PM   #1
stevealbrech's Avatar
Grayslake , Illinois
Vent stack question
I replaced the vent pipes for both the grey and black tanks today. While doing so I noticed the rubber flanges attached to the tanks that the pipes slide into are just a slip fit. They vent pipes were not glued to the rubber flanges on the tank nor did they have a hose clamp or anything else to seal them. Is this normal?
stevealbrech is offline   Reply With Quote
Old 03-31-2014, 07:49 AM   #2
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Good question. You do not want them coming off from the bouncing down the road.
I would clamp them with hose clamps. BUT be careful not to tighten to tight so you don't crack the neck on the tank. Just tight enough so you can't pull it off.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 04-03-2014, 10:00 PM   #3
I have been giving this some more thought, and I am thinking there should be some play in the pipes to allow for the movement while driving. I can't access the flange area without cutting the floor, so I will put it back in place as it was and pack fiberglass insulation around it to keep it centered to make myself feel better about it
Old 06-03-2014, 07:25 PM   #4
Ottawa , ON
I'm on your side, dude. It is surprising how much movement can occur in an AS, and not just from travelling. Filling the tank, for example, most likely induces the tank to drop down somewhat.
Old 06-03-2014, 07:51 PM   #5
Mixter's Avatar
1976 27' Overlander
Mine were slip fit and clamped. No sealant.
Mixter is offline   Reply With Quote
Vent Stack Replacement Opinion Ganglin Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 08-06-2012 09:07 AM
Water Coming in the Reefer Stack PoconoAir Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 06-22-2007 11:44 AM
Installing soil stack covers Will Ackerman Roof Vents, Skylights & Fans 4 09-11-2004 06:20 PM
Vent stack covers silverhawk Roof Vents, Skylights & Fans 3 02-03-2004 04:35 PM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 05:29 PM
