Old 02-06-2016, 04:19 PM   #1
rec
1989 29' Excella
anywhere USA , full-timers traveling the country
vent pipe filters
When I turn on my back ceiling fan to blow in, it draws odor out of the vent pipe filter for my tanks and blows it into my rig -- bleh! Has anyone found a good activated charcoal or other vent pipe filter that solves this problem? I talked to the guy at Odorhog, but he says his filters quite specifically DO NOT work well with Airstreams.
Ramona Creel
rec is offline   Reply With Quote
Old 03-09-2016, 09:48 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Not surprised no response.... With that "problem" I add deodorant/enzyme to hasten breakup.... RidX now makes one that seems to work well and is cheaper than the "regular" product...
So far no "problem" for us...
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-09-2016, 10:55 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Open a window. You are creating a negative atmosphere. Without a way to replace the air forced out. It draws it thru the sewer vent.
Old 03-17-2016, 03:06 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Oh...
I forgot...
Each flush must have sufficient volume to "push" into the tank... That will push a column of air up the "vent" pipe and keeping ng the stink in the tank... Shut the toilet hatch as soon as the water clears the valve....don't just keep your foot on the lever..keeping the valve open...
Also, turn off the fan for the duration of the flush.. Won't pull in much at all if technique above used.
Happy flushing!!!
Channing
WBCCI# 30676
Old 03-17-2016, 03:15 PM   #5
dznf0g's Avatar
Oswego , Illinois
You guys are missing OP's problem. She has her fan set to pull air INTO the AS, not exhausting air out of the AS. She is pulling fumes from the top of the stack into the living area.
I fear that the location of your stack to the FF is such that the only cure is dependent on wind direction and speed. Do you have two FFs and are both reversible? You may have no choice but to modify the fan(s) to blow out (the one close to the stack) and the other one to blow in.
-Rich-
Old 03-17-2016, 04:13 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Oops... Sorry for that.... Thanks DZ!
Channing
WBCCI# 30676
Old 03-17-2016, 05:33 PM   #7
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
I installed a charcoal in line vent filter on my last trailer in the black tank vent line. I think it was from Sealand marine and about $45 or so. Replace once a year or so
truckasaurus is offline   Reply With Quote
Old 03-17-2016, 05:46 PM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Once in a while I have the same issue. I just switch the fan to exhaust.
2012 Dodge Durango Hemi/AWD
holding tank vent filters -- anyone tried these? rec Waste Systems, Tanks & Totes 6 07-30-2012 10:34 AM
Generator filters ViewRVs Mechanics Corner - Engines, Transmission & More... 7 04-05-2004 08:17 AM
Brita Faucet Filters Sneakinup Water Heaters, Filters & Pumps 3 10-14-2003 06:21 PM
air conditioner filters canyonrich Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-27-2003 06:21 PM
AC Filters Craig Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-16-2002 06:14 PM
