Old 07-13-2009, 11:35 AM   #1
1961 24' Tradewind
Bend , Oregon
Valve brands
Does anyone know the brand of valves used on older AS? I have a '61 Tradewind. The valves appear in ok shape but I can't find any caps, connectors or hoses. The valve body is brass with an aluminum blade. There are 4 wedge shaped flanges on the valve. Any help would be appreciated.
Mike
Mike&Mary is offline   Reply With Quote
Old 07-13-2009, 12:46 PM   #2
Mike
That valave has been obsolete for over 45 years.
You can remove the fiberglass tank, cut out the brass valve, and glass in the new style square white bracket, and then go from there.
Many owners have already made that conversion.
Old 07-13-2009, 01:24 PM   #3
1961 24' Tradewind
Bend , Oregon
Thanks Andy, I think I posted too quick. After further research I discovered that i have a Thetford Brass collector and that I'm out of luck. My two options are not using it or replacing it. I'm hoping I can at least use it to route to an external gray tank so I can take showers and do dishes.
Thanks again
Mike
A/C in other locations than roof mount? Options, brands, tips... Rivka Furnaces, Heaters, Fireplaces & Air Conditioning 46 08-08-2008 01:00 AM
Pickup caps what to look for & what brands are good/bad LI Pets Tow Vehicles 22 05-08-2007 10:15 AM
3 different tire brands on trailer hapitauk Tires 5 03-05-2007 12:15 PM
New category idea: Brands & parts sourcing page surferstyler Forum Admin, News and Member Account Info 10 04-01-2006 08:30 AM
Why is Airstream any better than the other brands? Narnian Our Community 54 08-08-2003 04:13 PM
