Old 09-10-2008, 06:07 AM   #29
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Airstream65,
Did you get a working solution to your sewer dilemma?
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 03-05-2011, 07:36 PM   #30
2007 25' Safari FB SE
Hillsboro , Texas
I have had this adapter disconnect more then one time, I'm thinking of a hack sawing off the thetford end and putting something in its place lake a pull shut off and be able to connect using a Valterra fitting only any help would be great
carl johnson is offline   Reply With Quote
Old 03-05-2011, 07:49 PM   #31
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
We had the factory do ours, Thetford to Valterra so we wouldn't have to use the adapter any more.
Caroljb
photography
wheel interested is offline   Reply With Quote
Thetford Drain Valve - Blackwater JHBurns100 Waste Systems, Tanks & Totes 15 04-07-2009 09:39 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
Thetford vs Valterra pilgrim_still Waste Systems, Tanks & Totes 8 06-11-2005 01:34 PM
Source for Thetford valve? pilgrim_still Waste Systems, Tanks & Totes 8 07-11-2003 09:32 AM
Flush out connection JLD Waste Systems, Tanks & Totes 2 01-04-2003 09:06 PM
