Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 08-21-2008, 05:43 PM   #15
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
I don't want to hijack this thread, but it does relate to the current status of my dump valve on my 71 I need to replace. Should I go with Thetford or Valtera?
I have my own opinion. Don't confuse me with the facts.
Lumatic is online now   Reply With Quote
Old 08-21-2008, 05:44 PM   #16
Airtandem
Profile:  1998 30' Excella 1000
Davenport , Iowa
I recieved mine from CW today it is their part No. 35555..Price $4.00 and $5.50 to ship.
Airtandem is offline   Reply With Quote
Old 08-21-2008, 06:23 PM   #17
Airstream 65
Airstream 65's Avatar
Profile:  1965 26' Overlander
Winnipeg , Manitoba
Ok, here is a picture of my pipe.
Airstream 65 is offline   Reply With Quote
Old 08-21-2008, 07:51 PM   #18
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
OK, that's unlike any I have seen - maybe my adaptor is not the one you need.
The one I have stated on the package is thetford to valterra adaptor.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 08-22-2008, 06:05 AM   #19
DEITZ645
DEITZ645's Avatar
Profile:  2006 30' Classic S/O
1987 34' Excella
Mohrsville , Pennsylvania
Images: 84
Lumatic,
Since everything in the modern RV world seems to be Valterra, I would lean that way. Just easier all around, especially if you need replacement parts later on. Just my $0.02.
Carl, Elaine & Bailey Beagle
2006 30' Classic W Slide & Limited Package
1987 34' Excella 1000
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
AIR #14487
WBCCI #7429
DEITZ645 is offline   Reply With Quote
Old 08-22-2008, 06:23 AM   #20
DEITZ645
DEITZ645's Avatar
1987 34' Excella
Images: 84
Airstream 65,
That is like no other RV sewer pipe I have seen. From the picture, it looks like the flare at the end of the pipe goes all the way around. Was this at a permanent site? I am thinking maybe the flexible sewer hose was put over the flange and held on with a hose clamp.
This might work as a stop gap until you decide what you want to do. Measure the outside diameter of the pipe and head to the plumbing department of your favorite home improvement mega-wharehouse and look for a Fernco Coupling like this...
Then go to your favorite RV store and get a Valterra bayonet fitting similar to this one. I know it is threaded on one end and has a nipple to secure a cap, but you should be able to make it work with the Fernco Coupling.
I know this is not an ideal permanent solution, but it should allow you to at least use a Valterra sewer connection and dump your tanks until you can replace that "unique" sewer pipe.
AIR #14487
WBCCI #7429
Old 08-22-2008, 06:29 AM   #21
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
My Argosy 20 had a camaged fitting, rather than mess with it I repalced it. It's an option...
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 08-22-2008, 07:27 AM   #22
sander17
sander17's Avatar
Profile:  1996 28' Excella
Okemos , Michigan
Images: 42
Valterra vs. Thetford
Originally Posted by DEITZ645 View Post
Lumatic,
I would agree. On our '96, the black tank thetford valve has had an ongoing problem of not sealing after a few uses. After removing and cleaning it several times, I added a third valve to the system just upstream of the drain hose fitting. I used a Valterra since all of the seals are attached to the valve mechanism with the pipe connections being just square flanges. If anything goes wrong, you just remove 4 bolts and replace the whole valve (at $13.50 instead of $45+ for thetford) Another maintenance bonus is that none of the fasteners are threaded into plastic.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 08-22-2008, 08:09 AM   #23
Airstream 65
Winnipeg , Manitoba
Thanks everyone for the advice and the offers of parts! DEITZ645, it looks as though a temporary fix may be in order until I can do a complete replacement. The flare at the end of the pipe doesn't go all the way around though, there are four separate flares, but they are very thin. The second picture is a bit blurry, but it shows the grey water outlet downstream of the Thetford Valve. (Never thought I'd spend so much time taking pictures of a sewer pipe!!)
ID:	66017  Click image for larger version
Old 08-22-2008, 08:19 AM   #24
DEITZ645
DEITZ645's Avatar
1987 34' Excella
Images: 84
Airstream 65,
"Never thought I'd spend so much time taking pictures of a sewer pipe!!"
I have read a lot of threads about the older models not having a gray water tank and that it was just let to run out on the ground. I have never seen one, but it all makes sense to me now that I see how it was plumbed.
I think my Fernco Coupling idea would be a viable alternative until you work up the intestinal fortitude to drop the pan that covers your waste water plumbing.
Is there a cap that covers the pipe when not in use and in transit???
AIR #14487
WBCCI #7429
Old 08-22-2008, 08:37 AM   #25
Airstream 65
Winnipeg , Manitoba
I'm going to try your Fernco Coupling idea. There was no cap/hose etc when I bought the trailer.
Old 08-22-2008, 10:00 AM   #26
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
That may in fact be an original Thetford fitting - looks like they were changed in 1965 according to the VAC FAQ's page. Though someone here with a model in the early sixties should be able to confirm that (unless they have all been changed out). Not an answer for you but some background in any event. From VAC site:
Q: What’s with the older Thetford sewer fittings? Modern fittings wont fit.
A:1964 and older trailers have an older style of Thetford fitings than the later trailers. In 1965, Thetford changed the design, increasing the diameter of the lugs and sealing surface by an additional 3/8" in diameter. These modern fittings are still Thetford, which is the top-of-the-line fitting.
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 08-22-2008, 10:06 AM   #27
DEITZ645
DEITZ645's Avatar
1987 34' Excella
Images: 84
Airstream 65,
I guess this would be the answer to why the Thetford to Valterra adaptor is too large for your sewer pipe.
AIR #14487
WBCCI #7429
Old 08-22-2008, 10:14 AM   #28
Ganglin
Ganglin's Avatar
Gahanna , Ohio
Some replacement info. from the VAC on some older valves:
http://www.vintageairstream.com/FAQ/...dumpvalve.html
Gary
Thetford Drain Valve - Blackwater JHBurns100 Waste Systems, Tanks & Totes 13 11-19-2008 03:39 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 04:25 PM
Thetford vs Valterra pilgrim_still Waste Systems, Tanks & Totes 8 06-11-2005 02:34 PM
Source for Thetford valve? pilgrim_still Waste Systems, Tanks & Totes 8 07-11-2003 10:32 AM
Flush out connection JLD Waste Systems, Tanks & Totes 2 01-04-2003 10:06 PM
