Old 07-19-2009, 04:20 PM   #1
1984 31' International
Flint , Michigan
Valterra or Thedford?
Hey guys
The Black water valve on my 84 International was not sealing properly so I tore it apart today and the only name I can find on the valve is Anonda. It bolts on, is black in color and is about a half in thick...has anyone got an idea what make this is?
I appreciate your help
Dan
Grandpapa is offline   Reply With Quote
Old 07-19-2009, 05:41 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
if it's black I believe it is a valterra, Most Thedford are white in color.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-19-2009, 07:09 PM   #3
Flint , Michigan
Thanks Jason......I had checked out a couple of different suppliers and none of them looked like what I have. We'll give it shot and see what happens.
Dan
Old 07-19-2009, 07:24 PM   #4
Originally Posted by Grandpapa View Post
Hey guys
Dan
Anonda is the brand.
Dump valves are like many sears products, good, better and best.
Thetford is at the head of the "best" list.
Old 07-19-2009, 07:32 PM   #5
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Mine's a Valtera and it's quite legibly molded into the valve. Anonda is (was?) another maker of valves. See, here: RV Plumbing - Valterra Valve Body
Sounds as if some parts are interchangeable ... but maybe not all.
AirsDream is offline   Reply With Quote
Valterra to Thetford connection Craig Waste Systems, Tanks & Totes 30 03-05-2011 07:49 PM
Valterra Valve question 65CV Waste Systems, Tanks & Totes 0 07-14-2009 09:14 PM
Replace a Thetford Valve with a Valterra? thunder433 Waste Systems, Tanks & Totes 2 03-03-2008 04:41 PM
Thetford vs Valterra pilgrim_still Waste Systems, Tanks & Totes 8 06-11-2005 01:34 PM
