Old 03-29-2015, 07:00 PM   #1
2007 19' Safari SE
Buellton , California
Vacuum breaker-check valve
Anyone,
Can the Vacuum breaker-check valve be py-passed and replaced by an external vacuum breaker-check valve so that it does not leak inside my 2007 Saferi 19' Bambi every time I use the "No-Fuss Flush".
Thank you,
Trek61
trek61 is offline   Reply With Quote
Old 03-29-2015, 07:07 PM   #2
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
I assume you are talking about the blank tank flush. If so you either need to replace the valve or simply remove it. There are several posts about this issue on AF, and there are obviously pros/cons for each. If you want to replace it I believe there are higher quality brass valves available. I removed mine and replaced it with a PEX elbow.
Landrum is offline   Reply With Quote
Old 03-29-2015, 08:34 PM   #3
1974 Argosy 20
Kooskia , Idaho
Well, there is a valid code reason that it is there. I cannot recommend simple removal. A new one is not that costly. Just remember to blow it out with air when you winterize and you won't have to replace it again.
Old 03-29-2015, 09:02 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Unmm... I think the codes for anti syphon valves and check valves are a bit over the top, but frankly, if there is one place that I would INSIST on one would be a black tank flush devise...
Just sayin...
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Shower Vacuum Breaker in 2000 -34' jlovelady Sinks, Showers & Toilets 2 02-23-2013 06:04 PM
where can I find a vacuum breaker nipsey Plumbing - Systems & Fixtures 4 10-07-2012 05:57 PM
Vacuum Breaker on Toilet Hand Sprayer cal.caravel Fresh Water Systems 1 05-08-2012 09:29 AM
Toilet vacuum breaker Zeppelinium Sinks, Showers & Toilets 5 09-07-2007 04:05 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
