Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 04-01-2007, 06:56 AM   #15
Profile:  1977 31' Sovereign
McHenry , Illinois
Next year do not leave the tank valve open all the time. Discharge the tank only when it has built up sufficient volume to keep the stuff in suspension. You also might try to use one of those 90 degree bend flusher extensions on the garden hose once in a while (when you have a couple nice days during the winter) to stir up the tank before you drain it.
Old 04-01-2007, 07:31 AM   #16
Steve & Susan's Avatar
Profile:  2005 28' International CCD
Willoughby , Ohio
Hello -
We have a 2005 28' CCD and foound some construction debris that was jamming up our black water tank. Here are my two cents...
Go to the auto parts store and get yourself an inspection mirror - telescoping.
Then get a powerful flashlight - 3 D Maglite.
Put the mirror in the toilet with the valve open and shine the light either down the toliet hole or in through the black water dump valve. This should show you exactly what your problem is and then you can pick the appropriate solution from all of the above posts.
One thing we learned VERY quickly from tent camping, taking my Scout Troop camping, backpacking and now Streaming - a bad experience in the loo will ruin your trip. Also, you'll develop a tolerance for all things connected with poo!
Best of Luck!
Steve & Susan
2005 28' CCD, 2002 Silverado-C1500, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 04-01-2007, 08:52 AM   #17
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
glad to see you flushed out the problem....
so, where are you parked? I see your profile says "Boston"...not many campgrounds in the city, at least, of which I am aware.
We're having our first wbcci rally of the season in just 3 weeks at Salisbury beach. come on up and see us! we're a fun group.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Chuck is online now   Reply With Quote
Old 04-07-2007, 12:17 PM   #18
Fulltiming Since Sept. 06
matthewsim's Avatar
Profile:  2005 25' International CCD
overlander63, I learned about the hazards of the black hills and how to avoid them.
steelbird312, your technique sounds a bit dangerous, but I bet it works. I'll keep this in my bag-of-tricks for next time.
Darol and 2airishuman, thanks for the after-care suggestions.
Thanks again everyone!
matthewsim is offline   Reply With Quote
Old 04-07-2007, 12:41 PM   #19
matthewsim's Avatar
Sorry, I'm just now noticing the second page of replies. Thanks for the additional info dwightdi and szy8xj.
Chuck, it seems I'm still in some denial that I'm not living in downtown Boston anymore. I'm living in a trailer park in Westborough for the winter, which is almost an hour west of Boston. I'd like to find a place closer to the city and preferably a bit more scenic for the summer. I won't be able to make the Salisbury rally, but I'll definitely be hitting one soon.
Old 04-07-2007, 01:38 PM   #20
Profile:  2004 16' International CCD
1997 25' Safari
hamilton , Montana
2 air,, too funny!!!!!! have found that a small amount of dishwashing liquid and a bag of ice ,, and pouring dishwater into the commode helps to maintain regularity also,,, keeping a good mix of liquids and solids keeps the slinky smilin,,,, donna
dieterdog is offline   Reply With Quote
Old 10-24-2007, 10:08 AM   #21
johntavares1's Avatar
Profile:  Fall River , Massachusetts
Arrow digest
I had the same problem a couple of years back. I purchased some black tank additive that is called Digest. I put half the bottle in the tank and let it set overnight with the black tank value open. The next morning the tank had cleared and I have not had any problems since.
You may have to search the internet to find a place that sells this additive.
John
johntavares1 is offline   Reply With Quote
Old 10-24-2007, 10:16 AM   #22
Wink Unique rv digest
I search and found the correct name of the black tank additive. It is Unique RV Digest and there is a web site you can look at for more information.
John
Old 10-24-2007, 10:42 AM   #23
maxandgeorgia's Avatar
Profile:  1995 30' Limited
Ashland , Missouri
Oh, what a relief it is...when the black tank flows So glad to hear the plug has been pulled and you stayed dry. What a story!~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Water problems Dbraw Fresh Water Systems 14 10-03-2009 03:15 AM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 09:45 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 01:57 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 01:03 PM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 03:10 PM
