Old 02-03-2011, 08:01 PM   #1
1989 29' Excella
Tyrone , Georgia
Unable to dump black water tank before 20 deg. forecast
It will be very difficult for me to dump my black water tank in time. Is it possible to get by solely with antifreeze down the toilet this time?
mikeandnora is offline   Reply With Quote
Old 02-03-2011, 08:08 PM   #2
x
XXXX , XXXX
F&F is the tank full now? Are you using the trailer? If you can leave the furnace on it will send some heat down into the holding tank area between that and a generous amout of antifreeze you might be alright. How about the freshwater system is it winterized?
wasagachris is offline   Reply With Quote
Old 02-03-2011, 09:39 PM   #3
1989 29' Excella
Tyrone , Georgia
My wife convinced me to just make time for it, especially since my furnace won't fire (likely due to needing batteries I believe) I had better just do it right or I'm sure I will end up paying for it.. Thanks for the help!
Old 02-04-2011, 10:46 AM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Wifey had good advice. You were probably ok with temps just down to 20 overnight, but when you weigh the cost of getting unlucky compared to Just Gettin' It Done, getting it done wins, hands down.
Good for her. And you.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old Water Tank Removal & Clean up IronGiant Fresh Water Systems 9 06-23-2011 08:53 AM
New Slant on Tank Sensor Cleaning... Mexray Waste Systems, Tanks & Totes 5 01-30-2011 02:07 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 07:00 PM
replacing black water tank in 68 Tradewind clydecrashcu Waste Systems, Tanks & Totes 1 01-17-2011 10:28 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 10:19 PM
