Old 04-23-2011, 02:15 PM   #1
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Transfer pump question.
The park we stay at during the summer has 115v hook-up, but no holding tank drain or potable hook-up at the site. Have any of you found a pump to empty our black/grey water tanks into the Totes in the back of my pick-up? I'm getting a little old to lift those Totes after draining. As as retired irrigation contractor, I'd be leery (my pun) of using any of the units where the potable is hooked-in: there is no way to test that the "anti-syphon" valves are working and "backsyphonage" (a fire or heavy pull on the water supply) would be a huge concern. I'd think most parks would frown on those units. Thanks, M
ID:	127944   Click image for larger version
Name:	DSCN0459ob today.jpg
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 04-23-2011, 03:01 PM   #2
Images: 59
Get a 12V Jabsco Macerator pump. Works great, and they make fittings that adapt to regular drain fittings.
I appreciate your feeling about backflow prevention. Thanks.
Old 04-23-2011, 03:07 PM   #3
Mike Leary's Avatar
Images: 11
Thanks Mark, I'll take a look. Since we don't use TP in the black water tank anymore, simply use a sack and garbage it (don't ask why we quit using TP in the tank, the fix was not a pretty situation), I'm wondering if a macerator pump is needed?
Yes, the backflow/backsyphonage problem is huge in campgrounds, drives me nuts!
Old 04-23-2011, 03:16 PM   #4
Images: 59
If you get a Flojet pump kit from PPL, I think it will be just as cheap as building a system without the "macerator" capability. Comes in a nice storage box and hooks up to the regular 3" drain pipe.
Old 04-23-2011, 03:20 PM   #5
Mike Leary's Avatar
Images: 11
I'd been hoping to use 3/4" hose to do the transfer, but these pumps look like it'd be a bush-down nightmare.
Old 04-23-2011, 04:04 PM   #6
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
For your application, the types that use potable water for the pumping action would be of little value anyway. The potable water used flows out the pipe with the waste and you would fill up your tote long before you emptied the tank.
Ken
Old 04-23-2011, 04:09 PM   #7
Mike Leary's Avatar
Images: 11
Ken
And cause great embarrassment at the camp!
Interstate coach water pump problems solar-guy Sprinter and B-van Forum 10 06-03-2015 02:51 PM
No water from pump Castaway Fresh Water Systems 10 04-13-2011 08:59 PM
To replace the pump or not? MTsafari Water Heaters, Filters & Pumps 8 04-04-2011 07:20 AM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
